Front Leaf Removal
Old Dec 1, 2005 | 05:49 PM
51ford fan's Avatar
51ford fan
Wink Picture With Spring Leafs Removed
Here is a picture taken with the leafs removed.
Old Dec 1, 2005 | 07:59 PM
WillyB's Avatar
WillyB
Nice looking truck - except what is that white stuff in the first two photos?
Old Dec 2, 2005 | 01:45 PM
51ford fan's Avatar
51ford fan
Yea old man winter has struck, I hoping for a white Christmas this year.
Old Dec 3, 2005 | 09:19 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Nice truck. The one-piece glass looks great...
Vern
Old Oct 28, 2008 | 07:47 PM
04F150N56F100's Avatar
04F150N56F100
Just stripped my 56 springs and trying to decide how many to remove. I have seven leaves. If #1 is the shortest and #6 has the wrap, was curious about what benefit cutting off the wrap makes? Was thinking I might just remove #2 & #4 or possibly #1 & #4 or remove #2,#4,#6 ?
I also have some poly liner from Mid50. Does it compensate for thickness much? I think I would like to keep the stock U-Bolts - They appear to be in good shape...
Any suggestions?
Thanks guys !
Old Oct 28, 2008 | 09:05 PM
low54's Avatar
low54
start from the smallest to largest...#7 is your support leaf...get more of a drop by replacing with revers eye, unless your looking to put in a drop axel...
Old Oct 28, 2008 | 09:30 PM
04F150N56F100
I am happy with truck stance..looks ok
Really want to soften the ride a bit. Poly Liner should help, also beveled the ends of the springs.
Old Oct 28, 2008 | 09:34 PM
04F150N56F100
One more question
When installing the poly liner, instructions say to cut it 1inch longer on each end. What about the center bolt hole? Did you drill it or use a punch? I would think it might be too soft to drill well.
Thanks for any help!
Old Oct 28, 2008 | 10:09 PM
04F150N56F100
If leaves are removed, do I have to modify the u shaped clips that hold the leaves together? They would seem to be too large to clamp tightly.
Old Oct 29, 2008 | 04:56 AM
Goobzilla's Avatar
Goobzilla
I bought replacement spring clamps from Mid fifty. They are a 2 piece design and seem to work pretty well. Slide the tabs thru the "top hat" and bend 'em over like so:
Old Oct 30, 2008 | 01:53 PM
04F150N56F100
Goobzilla,
Are there 4 leaves or 3 in your picture? Did you use spring liner?
I noticed while reading the factory manual that some trucks had 8 leaves
and some had 7 (Heavy Duty). I've got 7.
Does it make sense to remove just one? (#2) or (#1 &#2) just improve the ride and maybe lower it a bit?
Also, it seems the hole in the main leaf is not centered....does the long section of the main leaf go back and shorter section up front? I forgot to mark it when removing...probably due to the large amount of grease on everything...
Thanks!
Old Oct 31, 2008 | 03:29 AM
Goobzilla's Avatar
Goobzilla
4 leaves left w/the teflon liner in between them...I think, I'll take a look when I get home in the AM.
Schickel
Nov 24, 2013 05:20 PM
kioolt
Oct 25, 2013 05:12 PM
CPTMidnight
May 23, 2011 03:12 PM
Rusty Bucket'
Mar 21, 2005 07:38 PM
