V B Upgrade saga
I am looking for the BOTTOM overload leaf you know - the thick flat leaf at the bottom - would you happen to have one? Do you split leaf springs up that way?
Bill: VIN # please - I gave my VIN
Bill: Normally they dont split up leaf stacks but I will check - Oh wait they do stock that part. It is $50.60 a piece.
Me: Are you sure it is the bottom overload leaf because they have a top overload leaf and that is NOT the one I want - I want the bottom?
Bill: Yes
Me: OK Bill here is the deal I am leaving in a few minutes to go buy the top 4 leafs in the stack for each side and will call you back after confirming they are satisfactory so that I can buy the BOTTOM leaf to make the set complete.
Bill: OK....
Me: I just want to make sure that I can spend $150 on the top 4 and you will still be able to get me the bottom.
Bill: OK....
Me: Will you hold on to my info so that when I call back you will be able to connect me with the right parts?
Bill: Sure
So then I drive 30 miles each way and spend $75 per stack (short 1) for a total of $150 and get home. Then I call Bill back.
Me: Can I speak to Bill?
Parts: Sure hold on... (20 minutes later )
Parts: Who are you holding for?
Me: Bill
Parts: Oh - no problem (few minutes go by)
Bill: This is bill
Me: Hi I just spoke to you a while ago about the leaf springs. I went to pick them up and I have them now. I want to order the bottom leaf.
Bill: ......
Me: The bottom leaf - I spoke to you about a getting the bottom leaf for a project I am working on
Bill:......
Me: You said you would hang on to my info until I called back
Bill: ....... uh ok - I dont have it
Me: OK here is the VIN for the Leaf (I give the VIN for the leaf)
Bill: We dont split up the leaf on that
Me: Bill... We have had this conversation already and you said I could go ahead and buy the top 4 because you had the bottom overload leaf and were willing to sell it to me for $50.60 a piece.
Bill: ......
Me: Bill?
Bill: They only sell leaf springs in full stacks - perhaps you were thinking of the Top overload spring because I can get you one of those...
What is the morale of this story??? Obviously it is not to listen to Bill at Tousley Ford. Morale #2 - I am probably an idiot for thinking that that would work...
Anyone have any ideas on what I can do with a set of top 4 leafs off of an F350. Anyone know where to find the bottom leaf?
Were you going to moddify the pack anyway? If you were going to moddify it what is the difference in thickness between our anti-wrap bar and that overload? You could just cut off the end of the ainti-wrap bar so you just have a short piece to to use in place of the overload. If you moddify the pack I don't think the overload does anything besides add height. Another idea I'd thought of was to order the taller blocks, moddify the spring pack, but take the overload off the bottom so there wasn't quite as much lift. I'm sure you'll figure out something that will work.
Good luck, in the end hopefully you will be able to look back and laugh...
Healy Spring Co Auto Springs, Minneapolis MN 55413 -- MerchantCircle.com
I used to deliver and pick up parts from Healy Spring when I was a kid over 40 years ago, so they have been in business a very long time. My Dad had some springs modified on his van years ago and I recommended them and he was very pleased with the service. Hope this helps.
I installed a set of modded B codes on my '05 V-10 4X4 back in February, I used the thicker EX spacers and the bottom two leaves from the EX's packs. I also used the cut-off slapper bar as an additional spacer placed below the B code's bottom thick flat plate. (So it doesn't come into play with spring compression.) I tow a very tounge heavy 28' toyhauler (real high tounge weight when the trailer's garage is empty!
) When hitched the 1400lb+ tounge weight most certainly loads up these rear springs. Under this situation the bottom thick flat plate does do what it is designed to do, spread the load out across a longer span of the leaf pack. That's my situation and experience, I know I'm over the rated hitch weight using WD but it does allow for a good demonstration of how much the modded B's improve these buggies, the stock springs settled right down on the bumpstops when hitched, now it squats about 1.25" with a few inches of travel left.
) When hitched the 1400lb+ tounge weight most certainly loads up these rear springs. Under this situation the bottom thick flat plate does do what it is designed to do, spread the load out across a longer span of the leaf pack. That's my situation and experience, I know I'm over the rated hitch weight using WD but it does allow for a good demonstration of how much the modded B's improve these buggies, the stock springs settled right down on the bumpstops when hitched, now it squats about 1.25" with a few inches of travel left.Trending Topics
They seem to be experienced with the spring swap which is reassuring - although they said they have not seen alot of them lately.
Thanks for the advice guys - this really helps!!
FYI I called Healey Spring as someone recommended but the Standard Station that answered the call said they have been out of business for 6 years.
That sounds like an excellent solution...let us know how it turns out and dont forget the pics.
Front used V springs with 80 k miles increased height by about 1.5 inches
Rear used B springs with >10k miles (with dually overload leaf) increased height by about 2.5-3.0 inches.
New Rancho rs9000xl springs with myride
Preliminary feelings on the swap... its a completely different vehicle. I hit a pothole and instead of the whole vehicle vibrating and moving laterally it only seems to affect the rear wheels where I can feel some extended vibration. Steering play seems fixed and it tracks down the road with very slight adjustments instead of 2 inches of plan and the back end wandering when I correct. I still feel like it could be tightened up but it is way way better.
Not sure what to think of the adjustable shocks. I am not able to detect a difference yet between the settings.
I drove from the shop installing them to pick up my Jayco 31bhs camper. 31 feet and 950 lbs of tongue weight. Without knowing exactly how much height I had gained I asked that their mechanic drop the WD hitch 1.5 inches (I am installing a propride hitch currently so I only needed to get her home).
On the way home it seemed better but as I hit bumps or experienced side wind it moved around a bit. Since I had not fine tuned it I just decided to hold my opinion until the propride hitch was installed. I assumed that if I fine tuned it it would tow better. As I stepped back from the EX hooked up to the trailer it appeared that the EX was finally level and not drooping in the rear with the 1k tongue weight. The vehicle and trailer looked level and like one. Still I was a little worried - with more play there could be the chance for more movement and it felt like it was moving - I am not above installing air bags.
I started installing the propride hitch on the trailer today in my driveway. A thunderstorm (not to mention my an anniversary dinner (16) with my wife) forced me to delay finishing it until tomorrow.
Have not tried to get it in the garage and will be seriously bummed if I cannot fit it in there. I will write up a review of the hitch if I can get it finished and tested tomorrow.
Anyone need these before I return them?
What size are they exactly. Would they work with the stock rear springs?
You should have no problem feeling the diff in the shocks. Try #1 setting go for a 5 mile ride and the set them at #5 and do the same corse and then at #9 and try it one more time, you will feel it!
