98 Explorer: no reverse?
Old Mar 15, 2005 | 06:45 PM
cjben's Avatar
cjben
I am posting this for a friend. The vehicle is a 98 explorer v6 4x4 auto tranny. somewhere around 110,000 miles. He was going to back it out of his driveway. He put it in reverse,and heard a pop. now he has no reverse,but forward gears work. does the tranny need a complete rebuild or is there something easier that could be the problem?. he told me he would sell it to me for a good price since he isn't really a ford person. If the tranny does need rebuilt,how expensive of a job is this? I don't really have $2000 to sink into a tranny right now. how hard is an explorer tranny to pull/replace? if i do buy it,thinking I could save some money by pulling the tranny myself and taking it to a tranny shop to have it rebiult. thanks for the advice,Ben
Old Mar 15, 2005 | 09:34 PM
norrislaketn's Avatar
norrislaketn
Replaced my tranny 98 5.0L AWD from Ford for $1500.00 rebuilt unit. Went to dealer and got it by using my friends account for wholesale. I was loosing reverse also. Fluid change did not help. Swapped in yard in a couple of days. I would do it again.
Old Mar 16, 2005 | 09:50 PM
cjben's Avatar
cjben
would it be the whole tranny if reverse went out all of a sudden with a noise like this one did? How is reverse activated? thanks again,Ben
Old Mar 17, 2005 | 09:32 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Ben, the 98 has a 5R55E transmission. If you drop the trans pan, you'll see the low/reverse servo cover on the passenger side, toward the rear of the trans. It's held on with 4 bolts, and when removed, you have access to the servo, O-ring, and spring.
If you wanted to pull the pan and take a look at the low/reverse servo, it wouldn't take much time. I suspect it's more than just the servo though, since there was a noise when reverse failed.....
Zorm71
1997 - 2003 F150
Apr 27, 2017 08:09 AM
stoven
Apr 22, 2014 08:48 AM
98gator5.4
Oct 11, 2011 09:17 AM
darickh
1978 - 1996 Big Bronco
26
Sep 2, 2011 05:24 AM
wickedwindsor
Oct 7, 2007 09:24 PM
