Air Sensor / Door Jamb Light Switch Help
side to the value cover or the breather element filter. this air sensor is about as big as a half dollar and has two little pipes with holes in the end of them that face inside the air cleaner and the other side that faces out side the air cleaner has a single fitting that a 1/4 or smaller black rubber hole would fit over. (question where would the hose run to?
2nd question i removed both door jamp switches. the ends rusted away inside. no wires at all. i see that the new door jamb switches have three fittings for three wires but where do i wire them up to?
i was hoping to just pull out the old ones and install the new ones.
not my luck thou. hope someone out there has been down this road and has a answer for me. thanks a bunch.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Welcome to this site!
I have a 79 F150 with a 351M engine. It has been awhile since I though seriously about it, but I believe the device you are referring to is a temperature switch located in the air breather. If so, this switch controls the valve in the nozzle of your air cleaner. The hose on one side of the switch goes to engine vacuum; the other side goes to the air motor on the intake nozzle of the air cleaner.
I believe the switch works like this: When the outside air is cold, the temp switch opens allowing engine vacuum to close the valve on the end of the air pick up tube. This allows the intake to suck warmer air from around the exhaust manifold, for better fuel atomization. Once the air coming into the air cleaner heats up, the switch closes, shutting off vacuum to the valve in the air pick up tube. Deactivated, the valve opens allowing outside air to enter the air cleaner.
Concerning the door switches, I have not taken the ones in my truck out yet, but will shortly since the dome light quit working. In addition, the electrical diagram that I have for my truck does not include the dome light. However, looking back to my old car repair days, I have noticed two types of dome light switches in cars: The first has a place for 1 wire only. In this configuration, the light already has a positive wire going to it. When the door is opened, the door switch grounds the wire on the back of the switch to the doorframe, and the light comes on. When the door is closed, the ground is again broken and the light goes out. The second type of switch I have seen on old cars has two terminals on the back. In this case, the switch doesn’t run either of the wires on its backside to ground, it shorts them together. Either switch can work in you application.
If your current switch has only one wire, you may try the following:
Using a multimeter or a continuity checker, check for continuity between the leads on the back of the switch and the switch housing. If you find one, activate the switch to see is continuity is disrupted when the switch is pressed in. If so, hook your wire to this terminal and you should be good to go. If you can’t find one that shorts to the switch housing, test for continuity between the leads on the back of the switch. When you find this continuity, see if it is disrupted when the switch is activated (pushed in). Once you find these leads, attach the wire from you old switch to this terminal, run the other to ground. This should do it.
I don’t have my truck with me today or I would pop the door switch out to see what the other side looks like so that I could give you better information.
Please write back and let us know what you find.
John24255
When the door is shut, the connection pins are spread from the metal band inside the other part of the switch.
The pin switch can also rust so badly it breaks apart.
But, Usually the contacts on the back of the switch corrode so badly they fail when they are supposed to come in contact with the band of metal.
The connector is a triangular pin type.
A file or emery cloth can clean them up.
Then use some di-electric grease to protect them.
John24255
The door jamb switch is the same, 1973-1996. D3TZ-13713-A
It has placements for three wires. with a triangular connector.
New switches are adjusted long, and you slam the door closed to adjust them to the proper length.
The three wires that are used with this switch are...
1: Green/Yellow stripe: 12V constant power.
2: Black/Blue Stripe: 12V switched power for the dome or underdash courtesy lamps.
The third wire is NOT used on the 1973-1979 pickups... Only used on 1980 and/or 1984 up...
3: Red/Pink stripe: 12V switched power for headlamps on warning buzzer, key in ignition, or door ajar.
<hr>
If there is only one wire in the connector on your truck, then the second wire fell out of the connector and is somewhere in the cab.
<HR>
Both my '74 Explorer and my '73 F100 Custom Cab parts truck have a single wire plug going to a single contact switch. There was no extra wire to fall off...much less a plug that fits the triangluar plug on the new switch.
As I said previously, the same Door Jamb switch was used 1973-1996, D3TZ-13713-A, and it has a three wire Triangular connection. The connector on the truck is also triangular to match, but only has two wires on the truck side. The connector # is C-703 in the wiring diagrams.
Wire colors at door jamb switch connector per the 1973 and 1974 F-series Factory wiring diagram:
1: Circut #54: Green/Yellow Stripe: 12V constant Power from fuse panel
2: Circut #53: Black/Blue stripe: 12V switched power to dome lamp.
3: Unused
Both of these wires are in the triangular connector #703, and the third spot is left unused. Connector#703 is located on both the driver and passenger side. It's located right behind the hole in the "A" pillar where the switch screws into. Normally you unscrew the old switch and the connector and wiring comes out of the small hole. You unplug the old switch, and plug in the new one, feed the connector back through the hole, and screw it in using a socket. If you cant find the connector and wiring then you will have to dig for it behind the dash in the general area of the hole in the A Pillar, and feed it through the hole to plug in the new switches.
I also owned a 1973 F-100, and changed these switches out. So I can confirm first hand that the factory information is correct.
The drivers side Wires that go through the A Pillar area: Not all wires may be present due to options or there may be empty connectors in the area...
Cargo Lamp: 2 wires: Green/Yellow and Black/Blue
Roof Marker Lamps: 1 wire: Brown
Door Speaker: 2 wires: Black/White Hash and Black
Door Jamb switch: 2 wires: Green/Yellow and Black/Blue
Dimmer switch: 3 wires: Red/Yellow and Red/Black and Green/Black
Hope this helps...
