Air Sensor / Door Jamb Light Switch Help
Old Jan 27, 2010 | 09:01 PM
ArcadeTom's Avatar
ArcadeTom
Sorry for the late post, but I just got out in the garage after work tonight. After digging and looking with a brand spanking new LED flashlight (amazing what good lighting can do) I found out you are certainly correct. I'll try not to doubt you again.
There were another set of wires in the door pillar with the correct plug - AND - the remaining piece of the original switch which had broken off. The weird part is the remaining piece on the switch looks like you can take a "bullet" type terminal and attach it.
I did install both new switches and amazingly enough I now have light when opening the doors.
Thank you sincerely for your help and the wire colors you posted helped me immensely!
Old Jan 27, 2010 | 09:36 PM
Tees77f150's Avatar
Tees77f150
This is a great piece of information. My passenger side does nothing, the switch if you push on it, it seems to function just like the driver's side, but nothing. So I will be tearing into it here soon! Sounds like someone is up for some rep points!!!
Old Jan 27, 2010 | 10:54 PM
ArcadeTom's Avatar
ArcadeTom
Yep. I already left rep for the great help provided.
Old Jan 28, 2010 | 08:06 AM
fordtech08's Avatar
fordtech08
Originally Posted by 81-F-150-Explorer
The door jamb switch is the same, 1973-1996. D3TZ-13713-A
that is no longer a valid part number, the new Motorcraft number is sw6345
just in case anyone needs a new switch
Old Jan 28, 2010 | 04:11 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Thanks for the additional info. Ford is notorious for updating part numbers at a drop of a hat.
Old Jan 28, 2010 | 04:16 PM
fordtech08's Avatar
fordtech08
yeah the parts guy was surprised that I could even get the switch, even more surprised when it had an 06 part number
we287gn
Feb 1, 2015 10:14 AM
rbaruffi
Oct 3, 2011 10:39 AM
Shane in WI
Mar 19, 2010 06:33 PM
cwooten63
Feb 5, 2006 11:13 PM
MuchToMyDelight
Jun 21, 2003 01:19 AM
