Sponsored by: Real Truck
Headache Rack
Old Mar 14, 2005 | 07:36 PM
brwolfjr's Avatar
brwolfjr
Headache Rack
I am looking for a headache rack for my truck. I was wondering what you have. Likes and dislikes. It will be more for show. I have a SC short bed in dark shadow grey.
Old Mar 14, 2005 | 09:33 PM
csx6025's Avatar
csx6025
Headache rack
I have a Back Rack. Ordered un-painted, then painted it dark shadow grey to match truck. Check 'em out at backrack.ca
Old Mar 15, 2005 | 08:54 AM
f350xlt460's Avatar
f350xlt460
Here is a pic of the one i made for my truck.
I love it.
Oh, also check out the bumper that i just finished for the dually
Old Mar 15, 2005 | 10:51 AM
CmprSpecial's Avatar
CmprSpecial
I too have a backrack.. It was a very easy install, no drilling at all.
Old Mar 15, 2005 | 03:59 PM
Badford's Avatar
Badford
how much are you willing to spend?
Old Mar 16, 2005 | 06:38 AM
brwolfjr's Avatar
brwolfjr
$250 or so. I am more interested in quality. I see weatherguard now has one but it doesn't look as well made. It is a onesize fits all.
Old Mar 16, 2005 | 07:21 PM
brwolfjr's Avatar
brwolfjr
I just ordered a backrack $233 delivered
Old Mar 16, 2005 | 10:51 PM
GREYF250's Avatar
GREYF250
Take a look at ProTech racks. Well made and decent looking, many varities.about $300 new.
http://www.protech.net/cbgrdmeshlmbrstp.html
I had one on my 87 F150 and really liked it for a canoe rack too, With my SD I went with a bed cover so have not put it back on. In fact if someone wants it for $125 and are in the Seattle area let me know. (excellent condition)
eric
codog1@comcast.net
Old Mar 20, 2005 | 09:14 AM
brwolfjr's Avatar
brwolfjr
cmprspecial - how did you run the wires?. IE - what path did you take? I am looking at adding a pair of Hella 500 fogs and some sort of yellow strobe.
I installed the rack Thursday. 15 minutes tops! However I installed the lettering facing the cab. Less obvious to my wife. No need for that discussion yet
Old Mar 21, 2005 | 07:53 AM
CmprSpecial
There are 2 options.
Near the parking brake on an '04 (somewhere else on other model years) are 4 wires called "customer access" wires, originally installed to run the PTO if equipped. They go from there, out to the engine compartment near the left hood hinge. They are blue, red, white and Black.
For me, I had so many things to run, I bought several feet of 10 gauge trailer 7 wire cable from the RV place. There is a small pass through on the right side of the firewall at the bottom of the dash. I popped the body plug out and ran the harness through there.
Once you get it out of the cab, wire ties did the rest.
PM me if you need any further description.
Old Mar 21, 2005 | 07:59 AM
brwolfjr's Avatar
brwolfjr
I was wondering where you ran the wires from the rack. Did you straight down between the cab and bed or did you drill into the cab?
Old Mar 21, 2005 | 08:06 AM
CmprSpecial
I ran the 7 wire cable between the cab and the bed, under the cab along the right side rocker. I used some of that wire loom covering to make it pretty. There are some little supports that worked as a channel to the right side fender. From there, the cable goes into the cab through the hole I described above behind the fender liner.
If you have to run less than 4 circuits, use option 1 from above and run them on the left side up to the harness where the customer access wires are. That way you don't have to run another wire into the cab, they are already there.
Old Mar 23, 2005 | 09:32 PM
brwolfjr's Avatar
brwolfjr
thank you for the help
doubledip
Jul 1, 2017 09:00 PM
Johnpsz
Mar 27, 2017 12:25 PM
spook222
Nov 18, 2016 09:57 PM
Gobblin Tom
Sep 13, 2016 09:44 PM
dyna
Sep 2, 2010 08:35 AM
