Transmission wont move
Old Mar 14, 2005 | 02:30 PM
linnie morvent's Avatar
linnie morvent
Unhappy Transmission wont move
We have a 1992 ford exployer 4wd we have changed the transmission,transfer case,and torgue converter and it still wont pull Please help
Old Mar 14, 2005 | 08:43 PM
4x4pete's Avatar
4x4pete
if you put it together right it can be two things a bad rear end (the driveshaft turns) or you instaled a bad transmission
Old Mar 14, 2005 | 09:15 PM
stuart1's Avatar
stuart1
The splines could be stripped in the transfer case to transmission.
Old Mar 16, 2005 | 07:26 PM
mike93's Avatar
mike93
does the engine rev up like in neutral or does it feel like you are trying to drive against the brakes? is the new transfer case in neutral when you think it's in high or low? I only ask that last one cause a friend pulled a joke on another friend by slipping the t-case into neutral. The guy came to work in another car thinking his tranny was gone
Old Mar 18, 2005 | 09:36 AM
johnboy427's Avatar
johnboy427
Ran into this once, a guy thought he shelled his auto in a 95 exlplorer pulled it and the flange on the back of the crank came out with the tq converter, not an issue if you changed the tq conveter you probably would have noticed this.
-johnboy
2FordTrucks
Jun 19, 2022 08:29 PM
Jagster66
Sep 18, 2013 07:32 PM
mrchili9
1983 - 2012 Ranger & B-Series
Dec 20, 2012 08:58 PM
Rod Kimble
Jan 14, 2012 02:31 PM
zippy
Dec 31, 2000 06:09 PM
