EGR Valve PROBLEM!
Old Mar 14, 2005 | 01:41 PM
timbersteel's Avatar
timbersteel
Angry EGR Valve PROBLEM!
I have a 1992 F150 I6, and I am now attempting, and have been for the last hour and a half to break loose the EGR Valve from the Exhaust pipe that runs back up from the catalytic converter. I have used WD-40, and even let this thing soak for a day when I was at work yesterday and still using WD-40, and will not budge. I have even warm the pipe up with engine heat and still will not budge. With the amount of force I am applying to break this loose, I am worried that I will end up breaking something, such as the pipe, or the manifold where it connects. If anyone has ANY ideas, I would be more than apt to listen to them!
Old Mar 14, 2005 | 01:57 PM
timbersteel
Just wanted to add to my post, I was reading a few of the EGR Valve Problems in the Forum and I can reading that you guys seem to be using PB Blaster, I have used it quite a bit at work for myself, but never really have sene much difference in the effect it has on the removal.
Sorry for the addendum, but was just curious..
Old Mar 14, 2005 | 02:56 PM
dieselsaurus's Avatar
dieselsaurus
PB Blaster is considerably better than WD-40. I have used both as well. I replaced the header gasket on my last truck. I sprayed the 18 year old bolts with PBB a couple of days before and they spun out with ease.
It's a kind of magic
Old Mar 14, 2005 | 04:07 PM
timbersteel
Talking
Hey, I hear ya there dieselsaurus, I just got the up-pipe removed and would you believe, 4 squirts of PB Blaster, and a littel force, no heat, it spun right off, let it soak about the length of a cigarette..I'm AMAZED!!
Thanks Again dieselsaurus for the reply!
Old Mar 14, 2005 | 06:29 PM
GST97's Avatar
GST97
If I remember right, the EGR threads might be reverse threaded.
I know when I changed mine it was very difficult, but for some reason I think I remember having to turn it the 'wrong' way
-Chris
Old Mar 14, 2005 | 09:38 PM
MemOrex's Avatar
MemOrex
yea the threads are reversed. I tried and TRIED turning it counter-clockwise, until someone mentioned it's clockwise thread.
mikewrt
Jul 10, 2009 06:16 PM
Nightrain
19
Mar 10, 2007 07:33 PM
WALFORD'S 56
21
Nov 26, 2006 12:59 PM
feblock352
Mar 15, 2005 06:52 AM
Zoombah
Modular V8 (4.6L, 5.4L)
Apr 5, 2004 08:32 PM
