Dear Ford
Old May 31, 2001 | 09:29 AM
slikness's Avatar
slikness
Dear Ford
1) Advance your timing until your truck begins to knock on hard acceleration, then back off 1-2 degrees.
2) Side gap the plugs (about a 10% increase in mileage on my 351W)
3) I had great mileage with my 2.73 rear gears and still had pretty good grunt for towing when I had the 300.
4) Get a good road tread on your tires, keep them inflated properly
5) Replace your stock fan with an electric fan.
6) Aftermarket ignitions are great, (I've got an MSD 6A), slap in a new distributor or get yours rebuilt while you're at it.
7) An OD tranny will help a lot. (anything to keep the rpms down)
8) Open the exhaust (headers or at least a cat-back), hi-flow cat, no muffler or a hi-flow muffler
9) Check and correct vacuum leaks
10) Rebuild the carb, try running a little leaner
11) Synthetic oil, tranny fluid, and rearend fluid
Good luck,
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old May 31, 2001 | 11:09 AM
Raul's Avatar
Raul
Dear Ford
Y'know Slik, with the price of gas nowadays, a 10 percent increase in mileage (or anything close to it) may off-set the cost of plug replacement.
Have you run the side-gapped plugs long enough to estimate how much their service life is shortened?
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
Old May 31, 2001 | 05:00 PM
87f250's Avatar
87f250
Dear Ford
ok, another stupid question. what is side gapping and how do you do it?
87 f-250
" if you are going to have a bear, it might as well be a grizzly"
4.9 granny tranny 4.11 gears
Old Jun 1, 2001 | 05:43 PM
rocky's Avatar
rocky
Dear Ford
I suggest run your tires over-inflated by about six pounds. The pressure stamped on the side of the tire is for a "soft" ride.
Old Jun 2, 2001 | 01:28 PM
slowsix's Avatar
slowsix
Dear Ford
north5
Jul 6, 2007 10:38 AM
dhag911
Feb 18, 2007 03:17 PM
Daviddc114
Oct 11, 2006 09:39 AM
dwkremer
Aug 16, 2005 07:27 AM
dieingford
21
Feb 21, 2004 01:52 AM
