Clutch master pulling away
Old Jun 2, 2001 | 08:48 AM
slowsix's Avatar
slowsix
The T18 to ZF swap coming along but as you know nothing is easy the first time. I noticed as I waa bleeding the slave cylinder that where the master cylinder attaches to the firewall it is pulling away when you push on the clutch. It looks like the glue or epoxy holding the bracket on is coming apart. Any suggestions on how to reattach?
Slowsix
1988 4.9 2wd long bed
3.55
T18 out ZF in but not running yet
Old Jun 2, 2001 | 09:01 AM
dpattonfl's Avatar
dpattonfl
There should be two bolts holding the clutch master cylinder to the firewall.
Old Jun 2, 2001 | 10:19 AM
87f250's Avatar
87f250
welcome to the world of firewall stress. this is a common problem with some years, i just fixed mine two days ago when i replaced my master, the metal was so distorted around that top bolt i couldn't get a wrench on it to save my life- so i cut it off. ford makes a kit that bolts to the inside of the firewall and beefs up the area, but i just went a hed and made one of my own. clutch works great now!
87 f-250
" if you are going to have a bear, it might as well be a grizzly"
4.9 granny tranny 4.11 gears
Old Jun 2, 2001 | 01:28 PM
slowsix's Avatar
slowsix
Thanks for the tips. I will try to reinforce the area or try new bolts.
Old Jun 2, 2001 | 03:50 PM
brett_d's Avatar
brett_d
newrider3
41
Jan 18, 2022 05:41 PM
Poorboy1967
Sep 7, 2016 04:53 PM
bronco6767
Apr 13, 2016 05:20 PM
MPoulson
Sep 18, 2013 08:35 AM
slowsix
Colorado Chapter
Oct 26, 2005 11:03 AM
