Sponsored by: Real Truck
Auxiliary power source
Old Mar 14, 2005 | 11:49 AM
gmitchell's Avatar
gmitchell
I am looking for a ignition on power source under the dash and ran across an "Ignition Run Power Feed (Customer Access) fuse location #27 in the fuse panel under the dash on my 2000 F-250 SD.
Does anyone know where this goes? There's a 10 amp fuse in it but I would think if it's for customer access there would be a wire somewhere to tap into it.
Thanks.
Old Mar 14, 2005 | 12:00 PM
n578md's Avatar
n578md
Follow the OBD II connector wiring up towards the radio. You'll find a wire taped to the bundle and capped with black tape half way between the OBD II Connector and the climate control panel. The #27 circuit wire is white with light blue tracer.
Old Mar 14, 2005 | 12:16 PM
gmitchell's Avatar
gmitchell
Thanks n578md!
Old Mar 14, 2005 | 12:18 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
n578md is right about the wire location but on my 2000 DRW it I remember it was a blue or purple with a pink strip, ether way it should be easy to find and check.
Denny
