Sponsored by: Real Truck
removing emblems
Old Mar 13, 2005 | 01:07 PM
s2gots's Avatar
s2gots
removing emblems
Hey people,
I have an 04 f350 and I want to remove my emblems on the fenders, and the one on the tailgate. I would like to know if these emblems are just stuck on with adhesive tape, or are they bolted on too?? I ask this because even though I can see that theres some kind of 'tape' behind the emblem, I once did see a SD without the emblems, but had two holes in the fenders where the emblems once were.. anyone have an answer to this???? thanx
Old Mar 13, 2005 | 02:33 PM
Frobozz's Avatar
Frobozz
There are locating pins on the emblems that go into holes in the fenders. There are no fasteners behind the holes, so you just need to get the tape loose and off they come... but you will be left with two holes. Sorry...
Duncan
Old Mar 13, 2005 | 05:10 PM
stutterstan's Avatar
stutterstan
I,ve heard that you can take a piece of fishing line and work it back and forth to get under the tape, but then you have to get around the two tabs in the holes
Old Mar 13, 2005 | 07:25 PM
s2gots's Avatar
s2gots
thanx for the info guys, I appreciate it....
Old Mar 13, 2005 | 07:31 PM
jdadamsjr's Avatar
jdadamsjr
and sometimes a heat gun/hair dryer makes it easier for the fishing line to get behind it...
Old May 5, 2005 | 08:45 AM
PurerockRacing's Avatar
PurerockRacing
what about removing the black paint on the emblems, so they are all polished silver? I want to do this but do not want to remove the red Lariat logo. I heard brake fluid or acetone works great. Anyone done this? I want the emblems all silver (no black) and put them back on...
Old May 5, 2005 | 10:54 AM
Hockycop's Avatar
Hockycop
PurerockRacer:
Check out silverbullets truck. He used acetone and turned out great..........He has pics in his gallery
Old May 5, 2005 | 01:09 PM
jetact's Avatar
jetact
Pure rock,
Go to my gallery and look at teh exterior pictures. I took the paint off of all of my badges and I had Steve at www.billetbadges.com make a few custom ones.
Old May 6, 2005 | 10:39 AM
sriddle's Avatar
sriddle
Jet Act... Nice outfit. Where did you tie in LED's?
Old May 6, 2005 | 11:19 AM
jetact's Avatar
jetact
sriddle
The LED's on the running board posts just got tied into a parking light wire running to the back of the truck. The ones on the bottom of the doors got tied into the interior lights to come on when the doors open.
Old May 6, 2005 | 01:33 PM
Autobahn F-250 Lariat's Avatar
Purerock,
I acetoned my emblems(pics in gallery) and the red Lariat is just fine didn't hurt it at all just took all the black paint off
Old May 15, 2005 | 02:43 AM
Jokenring's Avatar
Jokenring
I used a putty knife to remove the badges. You just have to be careful not to gouge the paint. Lacquer thinner to remove the sticky from the paint, and dipped the badges in acetone to remove the black paint. My red XLT came off, but now my truck is just in stelath mode. Pics in the gallery.
Old May 15, 2005 | 02:50 AM
hc130flyboy's Avatar
hc130flyboy
I have always used piano wire, (obviously the thin stuff) Just start at one end and run it through. you dont need to use a sawing motion with piano wire. then work on the other side. pop it off and use some 3M adhesive remover to clean it off.
Old May 15, 2005 | 01:16 PM
2000silverbullet's Avatar
2000silverbullet
For removing paint on badges, all you need is a $3 can of acetone, an old toothbrush, tape, and plenty of rags.
Most will disagree about using a toothbrush to clean these since it'll splash acetone everywhere but if you tape off a big enough section of the truck and are careful, you won't have any issues. I used 3" masking tape (doubled up) all around the badge (tucking the tape slightly behind the badge) and then taped some rags/old t-shirts in about a 4' diameter around the badge to protect the paint. Then just dunk the toothbrush in the acetone and start scrubbing. You'll see results instantly. I even used some brake cleaner afterwards to clean it all up. It takes longer to prep the area than anything, but it's more than worth it. As hockeycop said (thanks btw), pics in my gallery. Good luck!
