351w dipstick question.....
Old Mar 13, 2005 | 12:08 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Hey fellas, I am dropping a 351w into my 82 bronco, it has the hole in the pan for the dipstick, what year trucks and engines can I find this from.
Also, the 302 I pulled ouot of the truck has the dipstick in the block.
Thanks, Clint
Old Mar 13, 2005 | 01:34 PM
aprice's Avatar
aprice
if the two motors are pretty colse to the same year you should be able to use the dipstick. i was forced to use one from a 302 when my dipstick tube rusted out. the 302 was an 87 and my 351 is a 1991
Old Mar 14, 2005 | 05:34 AM
munrow's Avatar
munrow
Good luck finding a replacement that old. Most likely they will be too rusted at the connection areas to be able to remove.
Just about any year/style that has the correct threaded compression-type fitting will allow you to work with it.
Put it on, change oil and filter, add the correct amount of new oil (remember filter), see where stick registers. That's your new guide. Might want to add one quart less, get it hot, check it to see where the one quart low mark is, etc.
When I put headers on my 351W, in a van, couldn't find a new tube and dipstick at a reasonable price. Trashed the old set removing exhaust manifold. The dealer wanted $70.00 for a new set that I would have had to modify, anyway. Had to make my own dip stick out of a length of the correct diameter brake tubing (Napa, $6.99). It came with the correct threaded connector to screw into the pan. With a tubing bender and tube cutter (and another piece of brake line cause I got carried away cutting the first one) I finally got an acceptable oil dipstick system using the original stick.
Old Mar 14, 2005 | 09:15 PM
BroncoRoadKill
Does anybody know what size it is, and is it a regular flare that goes into the pan?
Old Mar 14, 2005 | 09:27 PM
cjben's Avatar
cjben
depends how much you are willing to spend. i got one from jegs for around $40 last year
Old Mar 27, 2005 | 08:34 PM
BroncoRoadKill
So what years and engines did they use this style dipstick? What do I look for at a wrecking yard?
Old Mar 27, 2005 | 09:10 PM
TheWiz427's Avatar
TheWiz427
Another suggestion to finding one is Ebay!
Old Mar 27, 2005 | 10:02 PM
superhooperduty's Avatar
superhooperduty
351w dipstick
the 351w i removed from a 82 f150 had the screw in type dipstick, and it was easy to remove.
BossFan
Jan 6, 2019 07:14 PM
mattri
13
Jul 1, 2014 09:06 AM
Bovaloe
Jan 23, 2010 08:07 PM
whd507
Dec 15, 2004 05:42 PM
