Clutch safety switch?
Old Mar 13, 2005 | 11:31 AM
ATC_250SX's Avatar
ATC_250SX
Hi i have a quick question for you guys,
The place i work has an 89 f-350, 7.3l 4X4, with a zf 5spd, it is having issues with starting, it dosent want to crank, and if you fuss with the clutch pedal it will eventually start, (by fuss i mean in and out and such) but when i looked under the dash i dont see a safety switch, any ideas???? is it in the transission or something?
Thanks guys.
Old Mar 13, 2005 | 12:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine is by the clutch pedal to the left of the steering column.
Old Mar 14, 2005 | 01:20 PM
diesel_988's Avatar
diesel_988
The switch should be on the rod for the clutch master cylinder at the right end of the shaft for the clutch and brake pedals. You should check to see if the plastic bushing is gone out of the eye for the master cylinder shaft where it connects to the lever for the clutch pedal shaft. If you have to push too hard, it's usually that or there is a crack in the firewall where the shaft is for the clutch master cylinder where it's mounted and the firewall and is flexing when you push down the clutch pedal.
watashe7
Dec 3, 2013 06:09 PM
IDIDieselJohn
Nov 26, 2013 05:23 PM
Fryman
Nov 21, 2006 12:13 AM
lrstaz
1983 - 2012 Ranger & B-Series
Oct 17, 2005 02:16 PM
Old Salt
Oct 30, 2003 07:27 PM
