flame throwers!!!!
Old Mar 12, 2005 | 11:28 PM
slim_falcon's Avatar
slim_falcon
flame throwers!!!!
i got a 81 ford f-150 ranger xlt with good ol' home built smoke stacks an recently i decided i wanted to be goin down the highway with flames rollin outa them bad boys so i went n bought a bran spankin new 81 ford f-150 ranger ignition coil for a 302 small block V-8 an wired it positive, though a switch, an negative, grounded to the frame, an when i hit the switch THE DAMN THING DONT WORK!!!!!!! i've replaced the wiring, the coil, checked the switch,EVERYTHING!!!!! what in gods good green earth could be wrong with 'er boys? please help me out......
Old Mar 13, 2005 | 04:44 PM
Sycostang67's Avatar
Sycostang67
A lot of those flame thrower setup run off of propane, or there is some kind of interruptor. The one I saw, the guy had to flood it real good, and when he hit the switch, it cut the power from the ignition and sent it to the coil in the pipes. He would then switch back over before the engine died.
Old Mar 13, 2005 | 05:24 PM
86f15035s's Avatar
86f15035s
yeah like sycostang67 said you cant just put in a coil and expect it to shoot flames the coil has to ignite something.
Old Mar 13, 2005 | 07:08 PM
wtroger's Avatar
wtroger
The coil only discharges when the power is turned off the primary side causing the magnetic field to collaspe which in turn induces power to the secondary (high voltage) side of the coil. You only get one spark per on off cycle. For this to work you need some way to rapidly turn your coil on and off. Plus you need some sort of fuel in the stack if your truck is tuned right you won't be able to ignite straight exhaust gas.
Old Mar 13, 2005 | 08:15 PM
jrbosking's Avatar
jrbosking
I have heard of people putting spark plugs in the exhaust pipe. I don’t know how it works but I would like to figure it out.
Old Mar 20, 2005 | 09:46 PM
slim_falcon
hearsay
i've been told that the gasses have enuf flamability to em to still burn n i've seen em burn on smaller motors, how could i get a lot of sparks to go through there the way i've got 'er set up?
Old Mar 20, 2005 | 10:53 PM
michaelbarry's Avatar
michaelbarry
very recent discussion about this up in the General Automotive Discussion section
http://www.fordtrucks.com/forums/sho...d.php?t=356668
Old Mar 21, 2005 | 01:16 PM
slim_falcon
much abliged
thats a long convo, but they covered everything, thank you very much, i know a hellova lot more bout ignitions now....lol, thanks again....
djryano
1997 - 2003 F150
16
Apr 25, 2007 10:58 PM
81fordf-250
36
Mar 28, 2006 08:23 AM
david00f150
Jan 10, 2005 12:28 PM
kcw12
May 11, 2003 11:58 PM
Lynch01
17
Oct 30, 2001 09:27 AM
