Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Tachometer / Engine Analyzer?
Old Mar 11, 2005 | 05:19 PM
timjk69's Avatar
timjk69
Hi All.
Who sells a good, no nonsense, analog tachometer these days?
Craftsman sells an "Engine Analyzer". Thats about all I find online.
Don't know about the quality?
Any help appreciated.
Tim
Old Mar 11, 2005 | 05:31 PM
E-350Triton's Avatar
E-350Triton
If Sears is still selling the actron tach/dwell it's a decent unit.
Old Mar 11, 2005 | 06:44 PM
jbullfrog's Avatar
jbullfrog
Do you want an electric or mechanical?
Stewart Warner has had the mechanical tachs for years. This is the gauge that you hold in the center of the shaft you want to read.
http://www.stewartwarner.com/Catalog/tachhand.html
Otherwise check E-bay for an electric one.
Old Mar 11, 2005 | 07:52 PM
gbadgley's Avatar
gbadgley
I have a laser tach, that works off of reflection from tape. works great. I do a lot of diesel work so you just put a small piece of tape on a crank pully or flywheel, point & shoot. you can pick them up under $100. Greg
Old Mar 12, 2005 | 08:04 AM
MBDiagMan's Avatar
MBDiagMan
Please be more specific about what sort of tach you are looking for. Are you looking for a tach to mount inside the car, a dwell/tach or something else.
Have a great day,
Doc
Old Mar 12, 2005 | 10:30 AM
timjk69's Avatar
timjk69
Have a great day,
Doc
Looking for a tach/dwell (analog) that I can use under the hood. I had a nice OTC tach/dwell/multimeter and its giving up after about 20 years.
Tim
Old Mar 12, 2005 | 02:59 PM
gbadgley's Avatar
gbadgley
You will in all likely hood have a hard time finding an anolog type, unless it's at a fleamarket or garage sale. I don't think anyone makes analog anymore, let alone a dwell meter, most people now have no idea what dwell is. Greg
Old Mar 12, 2005 | 07:41 PM
MBDiagMan's Avatar
MBDiagMan
Fluke makes a VERY nice automotive digital meter that has dwell, tach and several other things and is a quality piece of equipment. It sells for about $100. You might be able to get one from Sears or www.toolsource.com.
I expect that you could go to about any flea market and pick one up cheap.
Good luck,
Doc
Old Mar 13, 2005 | 11:10 AM
timjk69's Avatar
timjk69
Found what I needed yesterday at Sears. Its a Craftsman Engine Analyzer. Its has a few more functoins than a really needed but I do like the fact that it has a needle I can watch.
I also spotted a battery load tester that I may pick up next trip. It's an Actron with a 130 amp load. Looks a little nicer tahn the ones I've been eyeing at Harbor Freight.
Thanks to all, Tim
Old Mar 15, 2005 | 08:19 PM
Demented5oh's Avatar
Demented5oh
i found one of these tach/dwell/multimeters still in the box when i bought my house. i don't think it has ever been used. what do you use them for?
Old Mar 15, 2005 | 11:20 PM
midlf's Avatar
midlf
How you use it is to give it away someone, like me, who knows how to use it. <grin>
Old Mar 15, 2005 | 11:44 PM
midlf's Avatar
midlf
Denented5oh now that I gave you a flip answer I'll do the real one. The Tach part of this meter does just what any tach does, indicates engine RPM.
The "dwell" part is what a lot of individuals are unfamiliar with. In a standard coil ignition system the coil must have current flowing through it for a specific period of time to charge the inductance enough to give you a spark when the circuit is interrupted. With a points type ignition system the points had to be set properly to give enough "on time" to the coil at high RPM's. The dwell was spec'd as so many degrees. The points were set using a feeler gauge and the correct setting gave the correct dwell. The dwell meter was used to check this. In an electronic ignition system the electronics take care of making sure the coil always gets the correct amount of dwell.
The multimeter functions are standard volts, current and ohms and it is used like any other multi meter except the scales are usually optimized for automotive use.
Old Mar 17, 2005 | 07:06 PM
gbadgley's Avatar
gbadgley
Midlf, better watch out, like me you are showing your age. I dont think a lot of people would have the slightest idea how to set up a point type system. Greg
Old Mar 17, 2005 | 07:37 PM
midlf's Avatar
midlf
Hey in the electrical forum someone was asking for advice on how to get a generator with a mechanical regulator to work. Now that's going back. BTDT but just can't remember anymore.
Old Mar 17, 2005 | 09:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Geee, and I know how to tune a voltage regulator, and how to set up dual points, and how to align the points with the proper tool, how to tune carbs, hone brake cylinders... -I must be OLD! My first three cars had generators, one even had a flathead. And I did not get into the REALLY old stuff.
sportsfreaked
6.4L Power Stroke Diesel
Jan 4, 2011 11:00 PM
billrd01
Garage & Workshop
Aug 20, 2005 01:10 AM
t4kne
Mar 19, 2005 09:06 PM
telesqrt
Garage & Workshop
Apr 26, 2004 12:31 AM
