Thermactor air compressor
Old Mar 10, 2005 | 03:12 PM
ReGGaTarT's Avatar
ReGGaTarT
If I remove the thermactor air compresor unit, will the engine run ok without it?
Do I have to block the exhaust coming out of the manifold?
Old Mar 10, 2005 | 09:37 PM
95 F150's Avatar
95 F150
If you have factory cats in the long run you're better off leaving it running to prevent your cats from clogging up. If propely removed it won't affect engine running, for example by plugging the back of the heads and removing/ plugging all vacuum sources.
Old Mar 12, 2005 | 03:48 AM
Dannym's Avatar
Dannym
Why do people want to remove this? It doesn't really add to the back pressure, does it? And it shouldn't really be much of a load in the serpentine belt, it's just a little air pump.
Old Mar 12, 2005 | 06:26 PM
95 F150's Avatar
95 F150
I went with aftermarket cats on my true dual setup and the air pump was no longer needed, that's the only reason I removed mine
ng19delta
May 15, 2015 10:44 PM
59INA40
19
Sep 16, 2010 06:02 AM
redrumybronco
1978 - 1996 Big Bronco
Jun 30, 2004 10:12 PM
dbuck50
Oct 30, 2003 01:54 PM
dbuck50
Oct 30, 2003 12:32 PM
