Sponsored by: Real Truck
99 SD Hub conversion question
Old Mar 10, 2005 | 03:01 PM
Mattcin's Avatar
Mattcin
Hello, I need to do a hub conversion on a 99 F-250 4x4 SD.
I want to go from the early (99) style 10mm flange to the later (99) style 13mm flange since the current 10mm ones in use are warped.
Besides the hub, rotors and new pads are there any other parts I will need for this upgrade? maybe caliper mounts or something??
Thanks
Matt
Old Mar 10, 2005 | 05:20 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 10, 2005 | 05:22 PM
mizzitch's Avatar
mizzitch
I switched to the new hubs and rotors with just the stuff you mentioned. Everything is working great - no more warping so far. There may be a few seals for the lock outs and such but that is all.
Old Mar 10, 2005 | 06:07 PM
99f350sd's Avatar
99f350sd
So you are saying you want to replace the bearings $250 a piece and the rotors .
You can use the newer bearing and the newer rotors and they will bolt up and be fine.
Thats what I've read I havn't done it yet...The parts should be different from 3-99 and after. Sure beats spending the big bucks for the bearings at the dealer cause you can't get the early one's aftermarket...Rotor warping has nothing to do with the early design,later design will warp just as easily.
Old Mar 10, 2005 | 06:24 PM
Mattcin's Avatar
Mattcin
Well...as long as the bearings assembly comes with the hub that has the lug studs in it. I don't see it for that price you have listed and find the dealer as the least expensive unless we are talking about 2 different parts.
I realize that but the hub portion is whats warped on this one and since they need replacement it makes more sense to go with the thicker design I would think.
Old Mar 10, 2005 | 07:03 PM
99f350sd's Avatar
99f350sd
Look at some of these pic's
hub bearings don't warp.. Rotors warp and change thickness to cause pedal pulsation.
The hub bearing 515021 costs about $239 thats without abs. Dealer prices are ridiculous. Never go there unless you have to.
Old Mar 10, 2005 | 08:16 PM
Mattcin's Avatar
Mattcin
Look at some of these pic's Ball%20Joint%20Installation
Thanks for that info.
The piece that is not straight is this one specifically the flange the studs are in that the rotor sets up against.
It may have warped from an impact..dunno. All I do know it that the rotor is straight but that piece is not so a brake pulsation is present.
The 239.00 price you are talking about must be just the bearing and not the complete hub with bearing. If it is can you give me the manufacture of that part number? I know Napa and Chicago Rawhide are way more than the dealers price.
Old Mar 10, 2005 | 08:33 PM
99f350sd's Avatar
99f350sd
Yes it must of been in an accident for that part to be bent..If it is bent your wheel and tire would shake violently. The hub is all one part..Try online or Car quest or auto zone..Most guy's lately have gone to car quest...Thats where I got that price..I have seen $250 prices as a common occurance. The 4 mounting bolts have to come out from the old unit and put in to the new unit. Some guy's have been buying new one's at the dealer.
Old Mar 10, 2005 | 09:25 PM
99f350sd's Avatar
99f350sd
http://www.oreillyauto.com/B2C/condi...&description=+
Prices
Old Mar 14, 2005 | 05:07 PM
Mattcin's Avatar
Mattcin
Thanks for the advise, I did find them for 263.00 vs much higher at the dealer.
Mark Alligood
Sep 5, 2015 02:58 PM
lowzone
Jun 27, 2013 12:55 PM
PMB44
Nov 26, 2011 10:59 AM
rdw516
Sep 20, 2010 07:01 PM
cochran226
Dec 22, 2007 03:39 PM
