map lights 86 f150
Old Mar 10, 2005 | 08:35 AM
dagray3's Avatar
dagray3
map lights 86 f150
I can't get the map lights to work in my truck. I checked the bulbs, and they're fine.
I was just wondering if anybody else out there has had issues with the map lights, and if so, how did you fix them? I am suspecting a grounded wire. the dome light works fine, but I think the map lights are on a different circuit than the dome light.
any ideas?
Old Mar 14, 2005 | 11:45 PM
mstarr's Avatar
mstarr
I would use a volt meter or test light and check for continuity to ground to see if it is shorted. Then leave one end of the volt meter/test light connected to the wire in the ceiling and check for continuity on the fuse box, just keep touching each fuse till you get a light or tone from the volt meter. Then you know exactly which fuse controls it.
84StraightSix
Aug 31, 2014 12:35 PM
djordan
Nov 13, 2013 04:48 PM
rwjr
Electrical Systems/Wiring
Oct 21, 2008 11:08 PM
ss87
Feb 25, 2008 07:47 PM
ChrisLambert
Jul 9, 2004 01:56 PM
