92 f250 map lights dont work
good morning, new here, i have just bought a f250 1992. the map lights dont work, i took off the dome light, then replaced the bulbs and re installed it.
still no map lights. im assuming it is getting power since the dome light works but not the map lights. (i also have a f150 94 that i have been taking parts from, i installed that one in the 250 and got the same thing, dome light works, map lights dont.)
hopefully someone has and idea, and thanks in advance.
The domelight has seperate wiring to the door switches. It is fed off the same fuse, but the map lights have a hot wire right off the fuse that goes directly to the maplights, while the domelights go to the switches first.
On the older trucks, the wiring came right down the rear driver's side cab, and ran along the driver's side floor. It's a bad area and easy for the wiring to get damaged.
josiewales
01-20-2017 02:06 PM
Birken Vogt
05-05-2016 11:47 PM
