transmition interlock???
Old Jul 8, 2001 | 10:59 AM
chrisa's Avatar
chrisa
I posted this on the Aerostar board because it's really a problem with my Aerostar, but my '95 F-150 seems to have the same feature. So I thought I might get some help here as well: I can't get my trans. out of park by moving the lever while depressing the brake pedal anymore. Now, the only way to get out of park is to have the key in the "off" (not "lock") position, then move the lever. Can anybody tell me how this system works and/or how to fix it? It's a '93 Aerostar.
Old Jul 8, 2001 | 11:16 AM
PAUL_2's Avatar
PAUL_2
The problem is likely the Shift Interlock Solenoid . First check to make sure it has power to it . If it does about all you can do is replace it .
Old Jul 8, 2001 | 02:13 PM
charlez's Avatar
charlez
My 97 Cougar has this feature and it annoyed me.
All I did was dig around under the dash untill I found the wire that went from the brake area to the shifter (floor shift). I just unplugged it and all is well. The solenoid is normally disengaged with the power off and then when you start the car, it energizes and locks the shifter. If you unhook it, it will never get power and therefore can't lock up the shifter.
Old Jul 8, 2001 | 05:47 PM
evenbogey's Avatar
evenbogey
SirChirpAlot
Aerostar
19
Oct 21, 2024 05:49 AM
asavage
Aerostar
May 7, 2012 03:27 PM
Normy
Aerostar
80
Dec 15, 2011 01:46 PM
Rowsdower98
Aerostar
23
Dec 17, 2005 01:16 PM
axl43
Aerostar
Dec 1, 2004 11:28 PM
