1978 - 1996 Big Bronco
need more cubic inches!!!
Old Mar 10, 2005 | 12:22 AM
Michael_85901's Avatar
Michael_85901
Smile need more cubic inches!!!
Hello I am new to this and hope I can get my question out correct I own a 1990 Ford Bronco and love it but the 302 is getting tired so I want to swap it with a 351 windsor and am wondering how much trouble I might run into doing this or is it easy??? any help,tips, or suggestions would be greatly appreciated!!!
Last edited by Michael_85901; Mar 10, 2005 at 12:33 AM. Reason: misspelled ford oops sorry
Old Mar 10, 2005 | 12:40 AM
ATVer1992's Avatar
ATVer1992
never did it but i think it should go rather smoothly. From what i understand the 351 just has a longer stroke. They should all bolt up the same, perhaps different exhaust manifolds? This is all just a guess though. I mean they sell it with both the 302 or 351.
Old Mar 10, 2005 | 02:56 AM
Michael_85901
[B]Thanks atver that is what I kind of thought I am just wondering I just don't know to much about fords only have had the bronco for a few months was all chevy before that I will of course post a message once I complete the swap to let everyone know what I had to do and how it works as I just got the 351w from the local salvage yard and am having the machine work done right now to accept the 427 stroker kit I figure once that is done my bronco will be very nice with the five speed that it already has!!!
Old Mar 10, 2005 | 03:06 AM
ATVer1992's Avatar
ATVer1992
how many miles were on that old 302?? I've got 270K on mine and its origional. A little sluggish but still keeps up with the rest of em. I'm planning on new injectors this summer.
Old Mar 10, 2005 | 05:15 AM
tex94F250's Avatar
tex94F250
Just curious, what 5 spd? Read mazda + 427 = greande.
Old Mar 10, 2005 | 07:29 AM
gjordan456's Avatar
gjordan456
I was checking into doing the same thing and from what I understand it's pretty easy, some of the things that you would have to change is the flex plate and you might have to streach out your Y-pipe, the part where I still a bit confused is the ecu, there is alot of great info in here, so keep reading!!
Old Mar 10, 2005 | 11:45 AM
iagainsti's Avatar
iagainsti
A stock 351 wont give you a hugh difference over your stock 302/better torque less rev. I would build-up your 302 or stroke it. A 302 can make amazing power if done right plus its probably a little sporter to drive then the 351. I have a 96' 351 and love the torque but miss having a high-rev V8.
Old Mar 10, 2005 | 12:48 PM
Kemicalburns's Avatar
Kemicalburns
well unless your bronco is mass air equiped that 351w built to a 427 will not work. even with mass air you will still need that aid of a custom chip or tweecer to get things dialed in correctly. Now if you were to drop in a mildly built 351w with proper cam that would be a different story. also a 427 is going to require some serious fuel needs so 42lb injectors will be a must a 255lph fuel pump just to name a few. Not saying it cant be done but expect to pay some serious coin. do a search on here for 408 build. there should be lots of info there for ya.
302 is best kept in a car, trucks dont need to see such hi revs. and all that money you dump into a 302 wont compete with a 5.8 with heads,cam,intake,throttlebody and a good exhaust setup.
Old Mar 10, 2005 | 10:27 PM
Michael_85901
Red face another reason to change!!!
just a reply my 302 has 127000 miles on it but the prior owner failed to tighten the bellhousing bolts which caused a small crack in the rear of the block that is causing no problems right now just trying to get ahead before it does plus I have always been more of a windsor fan my work truck is an 89' f250 with windsor and has 358000 miles on it and still pulls it own weight everyday!!!
Last edited by Michael_85901; Mar 10, 2005 at 10:29 PM. Reason: misspelled word sorry again
Old Mar 10, 2005 | 10:37 PM
ATVer1992's Avatar
ATVer1992
impressive. original or rebuilt? I can't wait till i hit the big 30, err... i mean the big 300,000!!!!!
Old Mar 10, 2005 | 11:02 PM
Michael_85901
the 89 f250 is original 358000 miles never rebuilt its a tank just keeps going and going hauls anywhere from 500 to 2000 pounds a day great engine built ford tough yup this is one of those for sure!!!
