96 explorer air bag code 52
Old Mar 9, 2005 | 05:24 PM
justanother1's Avatar
justanother1
The idler pulley had fallen off while we were going on a trip. We were about 1 hour from home when this happened. We drove our explorer home on just the battery. I have put a new idler pulley and tensioner pulley on with a new belt. I also had the fuse out for the air bag in the fuse box under the hood. I did this because I had 1 of the crash sensors behind the grille off the explorer. We were on our way to get this sensor from my cousin that has a wrecked explorer. Since I have fixed everything, now the airbag light is blinking code 52. I believe this code has something to do with: Backup power supply voltage. How can I clear this code?
Old Mar 9, 2005 | 10:12 PM
Franklin2's Avatar
Franklin2
Disconnect the negative and the positive battery cables and wait one minute, and then re-connect and see if it clears up.
Old Mar 10, 2005 | 04:17 PM
justanother1
I had the battery cables disconnected overnight and all day until I came home from work. I did this because I put the battery on low charge to build the charge back up. I still have code 52 flashing.
Old Mar 13, 2005 | 01:49 PM
justanother1
Code 52 Cleared
I had done a search on airbag code 52 and came across an old reply done by reberhardt. Without having an airbag scanner or going to Ford, you have to cycle the ignition switch on & off 250 times to clear this code.
jh818
Sep 28, 2013 07:34 PM
treeclimber
Nov 14, 2012 04:35 PM
87_gt
Apr 9, 2009 09:49 AM
ArtistsRifles
International Region
Jan 2, 2009 04:32 PM
Trwaters
Apr 24, 2004 02:22 AM
