Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Making sandblasting cabinet
Old Mar 9, 2005 | 02:30 PM
randylay's Avatar
randylay
I have seen on the net using a dishwasher to make a sandblasting cabinate. Steel interior and a big door that allows larger parts. Has anyone tried this and if so what are the drawbacks or other advantages? Any other suggestions would also be appreciated.
Old Mar 9, 2005 | 03:06 PM
RocketScience's Avatar
RocketScience
My buddy did this using an old electric range. It was more trouble than it was worth IMO. Another buddy built one using some ¾” plywood and 16 ga. steel sheet metal screwed to the interior of the box. Endless possibilities going this route –and- it looks a heck of a lot better sit'n in the corner of the garage than a hacked-up old dishwasher.
Old Mar 9, 2005 | 07:11 PM
triton_2002's Avatar
triton_2002
Once again FTE has the answer
https://www.ford-trucks.com/article/...g_Cabinet.html
Old Mar 9, 2005 | 07:35 PM
RocketScience
NICE find triton_2002!
Old Mar 10, 2005 | 01:12 AM
randylay's Avatar
randylay
Great article Triton_2002. Thanks! Now to work.
Old Mar 10, 2005 | 08:48 AM
snyiper's Avatar
snyiper
here is another....sorry guess it is the same
Old Mar 10, 2005 | 10:18 AM
MBDiagMan's Avatar
MBDiagMan
There is another IMPORTANT issue when building your own or even assembling one that you buy. If it is not tight enough to hold water, it will leak media like a sieve. BTDT.
Good luck,
Doc
Old Mar 10, 2005 | 03:45 PM
ranchero77's Avatar
ranchero77
one thing not to scimp on is the window glass. you don't want sharp glass breaking in your face. a good tempered glass or polycarbonate should be used.
Old Mar 10, 2005 | 10:15 PM
furball69's Avatar
furball69
YOu can get laminated glass like the stuff windshields are made of and that should work fine. I'll assume you know that you can get plastic shields for the window so you don't have to replace the glass every 10 hours of blasting.
6863m
Apr 22, 2011 10:55 PM
bkohne1
May 2, 2010 08:29 AM
TooTired
Garage & Workshop
Jan 18, 2006 01:14 AM
nice59fordf100
Garage & Workshop
Mar 18, 2002 07:31 AM
