Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Wrench for distributor bolt
Old Mar 8, 2005 | 09:57 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
Post 1973 351w
i am having trouble to remove the distruter bolt, is there any wrench that will fit
there, 1/2 socket with unsiversal did not help at all!!
Old Mar 8, 2005 | 10:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Buy a distributor wrench. It is a like a bent box end wrench that will reach down into tight spaces. You can buy them at a parts store.
Old Mar 9, 2005 | 09:33 AM
beartracks's Avatar
beartracks
aA socket with a universal joint also works pretty good.
Old Mar 9, 2005 | 12:07 PM
Mr.Ford 351W
GOOD! i did it!! found at PEPBOYS for 4.79
Old Mar 13, 2005 | 10:54 AM
Mr.Ford 351W
found a better way, return the wrench to pep boys!, i used a 1/2 socket (1/4in drive)\
with a 1/4 unvrsal joint and 3/8 to 1/4 adapter with an 3/8 rachet and extension
Old Mar 13, 2005 | 11:03 AM
CheapRanger's Avatar
CheapRanger
FYI, if you wrench often enough then the distributer wrench is a quick convience. As I help out at a garage, I picked up a set of six off evilbay for $20. Since I plan on building a hot rod (as soon as I can figure out what) they were a future investment.
Old Mar 13, 2005 | 08:55 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
The distributor wrench is the ONLY way to fly!
Dedicated tool for the job.
I've had one in the toolbox for more than 30 years.
Hint: Get an old 1/2" box end wrench. Put it in a vise and heat it up (cherry red), then bend it. Let it cool SLOWLY. You've already ruined the temper of the metal. You don't want it to become brittle.
My 2¢.
Old Mar 14, 2005 | 12:00 AM
460f250's Avatar
460f250
Be sure to heat it first. Wrenches don't bend without heat, they'll break.
Old Dec 3, 2022 | 12:50 PM
chucketn's Avatar
chucketn
I doug through Dad's work bench and found a Ford distributor wrench I made 30+ years ago for a Bullnose I owned at the time. I can't remember what year the truck was. I'm going to need that wrench for my new to me '83...
Old Feb 26, 2023 | 05:46 PM
chucketn's Avatar
chucketn
That wrench I made, turns out it's 9/16, and doesn't fit my current truck. So, I sacrificed a 1/2"-9/16" double box and made a new on that fits.
Chuck
bigreentruck
Dec 5, 2016 05:02 AM
mattnj
16
Nov 1, 2016 09:20 AM
oldboots1950
13
Aug 12, 2016 10:42 PM
bashby
Oct 16, 2015 09:17 PM
Monsta
Aug 6, 2008 10:24 PM
