I just finished my box for my 95 F150 regular cab. Its 7.5" at base 4" at top and is 14" tall and 48" long. And has space for 4 10" woofers and i was thinking abot getting 4 Infinity 1030w 10" woofers and a Infinity 7541A 4 channel amp with 139 watts RMS at 2 ohms...Any thoughts?
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Hello
I hate to be the bearer of bad news but
according to the info you supplied there is no way
you can make that setup work
that box you spec'd out comes to 1.430 cu. ft.
those Infinity subs require .75 cu ft Each
so you need 3 cu. ft. for 4 of those subs(sealed enclosure)
Box has a max. sub depth allowance of about 4 1/2" on center
probably slightly less in reality depending on actual sub
dimensions -magnet size etc..
That sub has a 5 9\16" top mount depth--
My recommendation if your have the box built already change your sub
selection--you need a shallow mount woofer
2 12" woofers will fit and sound much better than 4 10" in this box
check this link its the only decent option that I know of
Also, you're going to need to seal off each sub from the other. Since it looks like you are going to need shallow subs I would like to recommend Blaupunkt's Overdrive subs, I was just up at Car Toys yesterday playing with the different stuff, and I turned these on and all I have to say is wow. These things sound really good. But for size If I were you I would go with 2 12" subs rather than 4 10".
Hello
Josh
JB Customs
hey how'd you get 1.430? Maybe my math is wrong but i got..... .5*14(4+7.5)*48=3864/1728=2.2361/4=.56 each sub????
you need to measure inside box dimensions not outside
so I figure you used 3/4 inch MDF
so subtract 1.5 inch from each measurement you have
46.5 L x 12.5 H x 4.25 W
2470 cu in
divide by 1728
1.429 cu ft
in reality this number will be even on the generous side
because your woofers will displace some volume as well
though be it minimal-- 4 woofers can displace any from
.2 -- .5 cu ft.
