Offroad & 4x4
Hydro-cylinders?
Old Mar 8, 2005 | 05:00 PM
RawPower's Avatar
RawPower
Hydro-cylinders?
Who offers hydraulic cylinders?
Ive looked at AGR, Stazworks, WTO, and a few others, but they are all no good or rip-off's. 150 for a Ram? No thank you...
Who else has them?
Edit: Im looking for a 1.5" or 1.75" bore w/ 8" stroke...
Old Mar 8, 2005 | 05:35 PM
jesse460's Avatar
jesse460
I buy most of mine from here, www.surpluscenter.com
Old Mar 8, 2005 | 05:46 PM
fishmanndotcom's Avatar
fishmanndotcom
i bought mine at a local tractor supply store and it was $60
-cutts-
Old Mar 8, 2005 | 06:50 PM
jopey's Avatar
jopey
surplus center. 2x8. $55
Old Mar 8, 2005 | 08:26 PM
ivanribic's Avatar
ivanribic
Ebay - # 3878821915 The only thing I don't know is the direction of the mounting holes on the cylinder base. But I just bought one so I can find out. You can never have too many rams. I also have a 2" ram but I'm going to try them both to see how the response speed is. If you want I can post a picture of this ram when it arrives and let you know about the mounting holes. They're always on ebay from that seller.
Old Mar 8, 2005 | 09:07 PM
RawPower's Avatar
RawPower
I think I saw those, but Im going for something a little more "traditional" (if we are thinking of the same thing) for ease of mounting....
Edit: and with heims...
Edit 2: Thanks for the help....
Edit 3: http://www.surpluscenter.com/item.as...name=hydraulic -rebuildable is nice...
EDIT FRIGGIN 4!: Fishy, whats yours like?
I think (hope) thats it...
Old Mar 8, 2005 | 09:37 PM
ivanribic's Avatar
ivanribic
Well I've got to see how that rear mount is. You certainly could turn it but I'd prefer to have my hoses facing up rather than forward. I do wonder though if you would have enough room to use elbows on the hydro fittings and turn them facing backwards. Pretty much any of these rams can be rebuilt, it's just seals.
Old Mar 8, 2005 | 09:55 PM
fishmanndotcom
mine looks like this
-cutts-
Old Mar 8, 2005 | 10:18 PM
RawPower's Avatar
RawPower
No, a lot are welded together... Ones like fishy's are what im looking for.
Will the end rotate fishy?
Old Mar 8, 2005 | 10:20 PM
fishmanndotcom
yup... i had to twist mine prolly 30-35* b/c of where my mount is
-cutts-
Old Mar 8, 2005 | 10:23 PM
RawPower's Avatar
RawPower
Ok... Im gonna go get one tomorrow at TSC...
Old Mar 8, 2005 | 10:29 PM
fishmanndotcom
lol thats exactly where i got mine... while your there pick up the 3/8 to 1/4" reducers if you plan to run 1/4" hose. just something to think about
-cutts-
Old Mar 9, 2005 | 12:08 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
only bad thing baout those big rams is you need lots of volume to fill them, so it slowsd your steering down a good bit, i bought the kit from rocklogic4x4 and tapped my box, and got the ram monted up.....its sweet, with my stock saginaw i cn sit at idle and turn my wheels from lock to lock with the brakes applied with my pinkie its kicks butt
Old Mar 9, 2005 | 12:11 AM
ivanribic's Avatar
ivanribic
What size ram are you using KO? I'm HOping mine won't slow the steering down. That's why I'm going to try the 1.5 and 2".
Old Mar 9, 2005 | 12:30 AM
KubotaOrange76
2.0 is a waste for assist, 1.5 is plenty for hydr assist, i would only go with a 2.0 for full hydroim using the 1.5x8 from rocklogic 4x4....theres no reason to use a huge one with hydro assist...this one has all the darn power i need.... go to rocklogic4x4.com and check out their hydro assist kit, i got it for 240 froma vendor on pirate...comes with the mounts, hoses to the length u need, grde 8 bolts, and heims for the ends of the rams, and of course the small compct ram....relly nice kit, since i recently broke my sector shaft, i got anotherbox and me and fishy put a new sector shaft in my box and tapped it, and tonight i put her up on jackstandds and mounted up the ram and hoses.....its absolutly SWEET, going down the road there is no difference in steering, except for tons more power at slow speeds. just make sure you get a good sizd tranny coller and run it in the low pressure line on your ps pump.
