2002 Fog Lights
Old Mar 8, 2005 | 12:11 PM
duallydawg's Avatar
duallydawg
Exclamation 2002 Fog Lights
Ok, I know there has been several posts with a solution for EVERONE ELSE. I have searched several sites and seen several threads with my same problem but there seems to be NO SOLUTION.
<O</O
I have a 2002 F350 with an Aug 01 build date it was bought in Texas and does not have DRL. I have the auto lamp option. The fog light switch pulls out in the parking lamp position as well as the headlamp position. Fogs only work with low beams. I want the option to have the fogs work with the parking lamps but also have the ability have only parking lights on. Fogs with the high beam as well.
I have the infamous black wire at pin 13 on connector C270a on the CJB.
The Mod by SteveRacer at www.ssdiv.com/fog.html will not work.
The threads that follow also help others but not the early 02
https://www.ford-trucks.com/dcforum/DCForumID117/2425.html
https://www.ford-trucks.com/dcforum/DCForumID117/3491.html
Also who sells the bright box and the wiring harness upgrade? I have seen the links on the threads but they are no longer good. Parts search on FTE does not yield any results. I found a wiring harness at suvlight.com but cannot find any others and the APC brand does not seem to be available.
Any help would be appreciated and I thank you in advance.
2002 F350 7.3L DRW, AIS, Silverstars, Family Roadster
Old Mar 8, 2005 | 05:59 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Have you tried simpy jumping power from the park light circuit to the fogs? On my 01 the jump is pin 2 to 12 on the larger plug (there are two) on the headlight switch, with the wire colors being brown to white/black trace.
I gather it's not that simple on the 02, but might be worth a shot.
Old Mar 8, 2005 | 09:47 PM
duallydawg's Avatar
duallydawg
Already tried that. The early 02's are differant from all the rest.
Thanks for the input
Old Mar 12, 2005 | 08:58 AM
duallydawg's Avatar
duallydawg
2002 fog lights
Old Mar 12, 2005 | 05:15 PM
IABill's Avatar
IABill
Talking
Call the guys at motorhaven the new britebox should be in anyday that will do it all. I been calling them once a week, they probaly are thinking this guy is a PITA
ROADHOGE250
Mar 24, 2019 06:55 PM
SS70ElCaminoOwner
Jan 24, 2008 07:00 PM
92Bronco-SA-TX
48
Aug 9, 2005 02:55 PM
