I just bought an '02 Explorer XLS this past Saturday. I am new to Ford products as far as ownership goes. The odometer LCD display is really dim. I have tried using the dimmer switch but that doesn't change the brightness. If I turn on the headlights, it is even dimmer and almost impossible to read. Any ideas on what's wrong, or how to fix it?
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I haven't a clue. But LCD uses ambient light or a light source from somewhere, so there must be a bulb in there. Of course you will probably have to take the dash out to investigate, and that is never much fun.
Well, a new development... I tapped on the instrument cluster before I pulled out of the driveway this morning and the display went to it's proper brightness! Which leads me to believe it must be a bad cold solder connection. So far the display is working correctly now. I did a search and found a post on this same topic. Searched for "blackout" "odometer".
