Inline Six Timing
Old Mar 7, 2005 | 11:31 PM
Gregstopspeed59's Avatar
Gregstopspeed59
Inline Six Timing
I am new to this so I appreciate any help I can get.
91 f150 w/ 4.9L inline six
I replaced my distributor today and am unsure how to do the timing.
First thing is how do you get the damn spout connector off? Is there a special tool or something.
Second, the hood says to adjust the timing with the engine running, is this possible?
I am sure I will have more questions later.
Again any help is appreciated.
Old Mar 8, 2005 | 01:42 AM
paulfix's Avatar
paulfix
I pulled mine off with my fingers, I have a 93 tho so it may be different. Once off, you can use the marks behind the smog pump. I set mine to 13 btdc. Use paint to highlight the mark on the bottom pulley
Old Mar 8, 2005 | 10:39 AM
DannyP's Avatar
DannyP
Don't mean to hijack the post, but this is related.
The 300-6 EFI I am working on has 2 sets of timing marks. One set is cast into the timing gear cover and the other is a bolted on timing tab on the right hand side of the engine. Which do I use? Why are there 2 sets?
Thanks,
DannyP
Old Mar 8, 2005 | 11:58 AM
Silver Streak's Avatar
Silver Streak
You use the stamped steel on the right. Don't know why there are two sets of marks; maybe the others were used on carb engines or 240's?
The spout connectors should just pull out of its recepticle. If it's never been out before it will probably be hard to get out. The engine must be running to set the timing. My truck likes 14-16 degrees.
Old Mar 8, 2005 | 12:45 PM
cmlind's Avatar
cmlind
When finding the mark on the harmonic balancer, make sure you use the fine line that goes all the way across it. It may be hard to find. Do not use the V notch. Drove me nuts until I figured that one out.
Old Mar 8, 2005 | 01:13 PM
DannyP's Avatar
DannyP
Glad you mentioned that. The notch at the rear of the balancer is the only one I was aware of.
Thanks to all for the help.
DannyP
Old Mar 8, 2005 | 01:33 PM
noFordguy's Avatar
noFordguy
while you guys are talking about timiming.. i have a 92 f150 4.9 and the base timing is set at 10dbtdc. well when i plugged the spout in the timing didnt move???? some one recamended replaceing the module.
Old Mar 8, 2005 | 02:41 PM
M.Stephens's Avatar
M.Stephens
My advice -- forget the timing light. Turn your motor to #1 cylinder top dead center, now turn your distrinutor to fire on the #1 cylinder. Pit the cap on, leave the dustributor loose, crank the motor, rotate the distributor until the motor sound smooth. Works like a charm. USe the light and the marks are hard to even see and when it says it correct, even advanced a little, my motor wasn't running all that well.
Old Mar 8, 2005 | 05:42 PM
Gregstopspeed59
Spout did come off with a little muscle.
Got the timing adjusted seems OK. Only thing is after about a minute of running the timing starts to jump around a little (a couple of degrees up usually). Happened with and w/o the spout in. Is this a serious problem?
Thanks for all your help.
rustoleum82
Jan 26, 2016 07:56 PM
fordrules_2013
Oct 13, 2013 06:33 PM
coleboy11
May 8, 2012 10:54 PM
str8six
1978 - 1996 Big Bronco
20
Oct 9, 2002 08:15 PM
