Dana 44 question
Old Mar 7, 2005 | 08:51 PM
Firefighter8-1's Avatar
Firefighter8-1
Dana 44 question
so i picked up my dana 44 out of an 89 bronco this weekend for my 4x4 swap. i got it all apart, waiting for the funds to buy the hub,rotor warn hubs, ball joins and u joints. is there anything else i should be replacing here? also will the steering linkage from a 96 F150 bolt up to this axle? one last question is that are the 2wd and 4wd radius arms different? if they are does anyone have a set of radius arms theyd be willing to let go?
Old Mar 9, 2005 | 09:01 AM
Firefighter8-1
Question
anyone? i found the answer to my other 2 questions, just wondering about the radius arms now
Old Mar 9, 2005 | 03:39 PM
Chris_ce's Avatar
Chris_ce
I looked at a picture of the 2wd radius arms and they look like what used to be on my truck. So I would assume they are the same. Sorry but I hauled mine off to the dump a few weeks ago.
I would strongly suggest that you replace the axle pivot bushings with the poly superlift or comparable ones.
Old Mar 9, 2005 | 04:29 PM
Firefighter8-1
yea i was planning on doing that. i found a D44 rebuild kit on bronco graveyard which I think will have everything I need, just wondering about the radius arms as I don't have the funds to buy a lift kit with extended ones up front. btw hows your 302 w/ 3.55's and 35's?
Old Mar 9, 2005 | 05:03 PM
Chris_ce's Avatar
Chris_ce
I don't think the d44 axle kit will come with these. I personally believe that these are the major cause for front end wander and not being able to hold an alignment.http://www.suspensionconnection.com/...KF03018F5.html
My truck is pretty slow and eats a lot of gas. I will be changing gears soon to 4.11 so my gas mileage and take off power will increase.
Old Mar 9, 2005 | 07:01 PM
tite4x4's Avatar
tite4x4
I Just wanted to make a comment about the Gears, cause I currently have a 90 Bronco with a dana 44 up front. I would highly recomend at least 4.10 gears. and if you plan on going with 35" tires I would then go with 4.56 gears.
I have had 4.10 gears and 33" tires on my rig for several years both with NO lift and then with 4" lift. I just recently installed 4.56 gears and an ARB in the rear, and I'm about ready to do the same for the front.
oem78
Jul 10, 2009 08:28 PM
bremen242
Offroad & 4x4
Oct 7, 2004 09:18 PM
f150_514ci
Offroad & 4x4
16
Sep 30, 2004 03:52 PM
slimersoup
Offroad & 4x4
Jun 9, 2001 12:17 PM
