EFI 300 six differences?
Old Mar 7, 2005 | 07:06 PM
averagef250's Avatar
averagef250
Just bought an 89 ford E150 van for the injected 300 six. What are the differences between this engine and a 70's carburated 300; roller cam, main seal, balancing? Putting this engine with a megasquirt controller in a 70 F100 2wd. Don't want any surprizes when I try to bolt up motor mounts, old flywheel, etc. Thanks.
Dustin
Old Mar 7, 2005 | 09:42 PM
oldhalftons's Avatar
oldhalftons
the clutch pivot bolt holes changed a few times over the years. 2 bolt, 3 bolt and bellhousing mount. so make sure you have a correct bracket for the engine your putting in.
An EFI engine bolted right in to my 79, all I had to do was pull the sepentine balancer off and use the older brackets carb intake and a single vaccuum distributor.
No roller cam, they all are internal balance. EFI heads have 17 bolt holeson the manifold side. the heads also have heart shaped chambers and low compression pistons (overall a little higher compression). some early (87-early 88) EFI engines use cast iron 302 rocker arms
Old Mar 8, 2005 | 08:41 AM
Silver Streak's Avatar
Silver Streak
How would a 302 rocker work in a 300? A 302 rocker bolted to a 300 head won't even reach the valves. Unless the valve locations were drastically different on the 87-88 heads I don't think that works.
Old Mar 10, 2005 | 01:24 PM
averagef250
Thanks for the help. I think the original engine has the bellhousing mount, but thanks for the heads-up.
Dustin
70T351W
700
Apr 13, 2022 09:48 AM
OKC_65_F100
Aug 14, 2010 10:15 AM
OKC_65_F100
Aug 8, 2010 03:56 PM
70torino429
Apr 20, 2009 11:08 AM
red and white truck
Feb 20, 2005 03:33 PM
