Driveshaft:checking u-joints/yoke
Old Mar 7, 2005 | 12:51 PM
WVF150VIANC's Avatar
WVF150VIANC
Question Driveshaft:checking u-joints/yoke
I was under the truck Saturday checking my u-joints, or trying to. The u-joints all seem tight. I noticed no lateral movement at either joint. Am I checking correctly?
I did notice that where the yoke slides into the tranny extension (2WD), that I can push the drive shaft up and down and side to side. The movement I'm seeing is within the tranny, not at the u-joint itself. Should there be movement? I'd say total movement was 3/16 to 1/4", 3/32-1/8" each way from where it was sitting. This measurement was at the joint, but not within the joint..if that makes sense. I'm guessing those measurements, of course. Would this indicate a worn yoke? Can this cause vibration at highway speeds or just on take off? I do get a chatter on take offs, but I assumed this was my clutch. Sometimes, I'm a bad 2nd gear rolling stopper.
Thanks,
Rich
2000 4.2, 5spd, 2WD 107,500 miles
woodtrucker
Oct 27, 2013 08:18 AM
pickncrew
Jun 4, 2011 08:24 PM
staysbroken
15
Apr 18, 2010 07:40 PM
WVF150VIANC
1997 - 2003 F150
Mar 6, 2005 10:29 AM
rlh
1978 - 1996 Big Bronco
Jan 19, 2004 11:44 PM
