Sponsored by: Auxito
Driveshaft/U-joint check
Old Mar 6, 2005 | 10:20 AM
WVF150VIANC's Avatar
WVF150VIANC
Question Driveshaft/U-joint check
I was under the truck yesterday checking my u-joints, or trying to. The u-joints all seem tight. I noticed no lateral movement at either joint.
I noticed that where the yoke slides into the tranny extension (2WD), that I can push the drive shaft up and down and side to side. The movement I'm seeing is within the tranny, not at the joint itself. Should there be movement? Does this indicate a worn yoke? Can this cause vibration at highway speeds?
Thanks,
Rich
2000 4.2, 5spd, 2WD 107,500 miles
Old Mar 6, 2005 | 10:29 AM
mayhelm's Avatar
mayhelm
A little movement at the yoke is fine. You usually feel a vibration at take off when a u joint is going bad. When a u joint goes bad, it starts to lock up.
pickncrew
Jun 4, 2011 08:24 PM
BigAlsPSD
Sep 16, 2010 09:31 PM
User 71024
15
Mar 6, 2006 03:33 PM
rlh
1978 - 1996 Big Bronco
Jan 19, 2004 11:44 PM
