thanks for the help!
Old Mar 7, 2005 | 11:39 AM
garsten's Avatar
garsten
thanks to all who posted in the past about dropping a 460 into a truck covered in this forum. with the information i got by searching this forum, the engine/tranny dropped in with minimal swearing and no broken knuckles. i installed the 460 in a 68 F-100 2wd shortbed. i removed the radiator core support, grill, valence, and bumper to make things go as easily as possible.
i used the mounts from a 78 2wd supercab w/460 and L&L 79750D headers. the frame was drilled correctly to accept the engine support brackets and the PO had installed a 351M w/C6 so the tranny bolted up and its crossmember did not have to be moved. once i had the engine in far enough so the headers would clear the crossmember, i installed them loosely with only the front bolt so they could be moved/rotated as the engine was moved rearward and lowered. the headers touch the frame on the right side but a cutting torch will clean up that minor problem. i used a rear sump pan from the same 78 truck and have plenty of clearance between the pan and crossmember.
next minor problem will be acc's. i will only be driving the water pump, alternator and power steering pump. i have 2 crankshaft pulleys, one from a 70 lincoln and one from the 78 supercab. the alternator bracket from the 70 lincoln looks like it will work and i found a saginaw ps pump bracket which will mount to the 460 but i am not sure how the belts run. if anyone has a solution to the front dress issue, i would appreciate your input.
thanks again, cheers, garsten
mositso
Engine Swaps
13
Mar 7, 2010 07:30 PM
cadunkle
May 30, 2009 08:05 PM
2bunik
13
Apr 29, 2008 03:26 PM
bluestang65
Aug 3, 2004 09:10 AM
79Supercab
Jan 7, 2002 07:16 AM
