Tailpipe Removal
Old Mar 6, 2005 | 09:06 PM
xallxforxchristx's Avatar
xallxforxchristx
Tailpipe Removal
Hey Guys, is it hard to cut the welds that attach the muffler to the tailpipe? Right now I have a single in/dual out flow 40. I looked under the truck and it seems as if I paid for a pretty bad welding job. They already look rusty. Anyways, I was going to try and chop the tailpipes off right after the muffler just by cutting the weld. What do I need to do this?
Old Mar 7, 2005 | 03:47 AM
V10man's Avatar
V10man
Sawz-all, torch, hack saw, pipe cutter?? Sure the welds will rust if it's just plain welding rod or wire.
Old Mar 7, 2005 | 08:38 AM
fordfan302's Avatar
fordfan302
ive done this plenty of times, i just use my air powered cut-off wheel...but if your gonna use a hacksaw make sure to eat your wheaties because it takes alot of elbow grease
Old Mar 7, 2005 | 09:11 AM
xallxforxchristx
alrighty, hopefully this won't be that hard of a job...I'm guessing half an hour to a full hour. Hopefully all goes smoothly
Old Mar 7, 2005 | 09:59 AM
crecity678's Avatar
crecity678
if your not replacing the pipe make sure that the rest of the exhaust is supported well.
Old Mar 7, 2005 | 10:18 AM
xallxforxchristx
I got under the truck last night to check that very thing. The muffler is supported by one hanger. There is a bracket for another hanger, the hanger would just need to be welded onto the muffler. Would one bracket be enough to support it?
Old Mar 7, 2005 | 12:29 PM
crecity678's Avatar
crecity678
should be fine
Old Mar 7, 2005 | 03:29 PM
MemOrex's Avatar
MemOrex
lol, i agree on that hacksaw/wheaties comment.....sooo many times have i used hacksaws :0
Old Mar 7, 2005 | 06:44 PM
kens64's Avatar
kens64
Same here. I cant bring myself to use a hacksaw, WAY too much work.
Old Mar 7, 2005 | 09:01 PM
xallxforxchristx
Awesome, thanks for the responses guys.
Old Mar 7, 2005 | 09:27 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
exhaust pipe cutting
Use a chain roller cutter. Make sure your square and all cutters are in the same track. Plan "B" is your handy Sawzall with a fresh blade in fine tooth with good safety glasses.
Carl....=o&o>....
sjwelds
2004 - 2008 F150
Jul 29, 2011 09:29 PM
johnnybronco
Bronco II
Jun 27, 2010 04:37 PM
TallPaul
Exhaust Systems
26
Nov 13, 2007 11:01 PM
SmittyD
Bronco II
Mar 2, 2005 06:23 PM
SpokaneMan
Exhaust Systems
Dec 30, 2004 10:50 AM
