Offroad & 4x4
Warn winch having problems..please help
Old Mar 6, 2005 | 05:17 PM
99ls1z's Avatar
99ls1z
I got my truck stuck last night pretty bad. Call a friend who has a warn winch 8000xi (I think this is the name). Well he had to pull me a pretty good distance. After pulling me about 10 feet his winch started to get hot. We let it cool for about 30 minutes then tried again. It seemed weaker and only pulled me a couple of feet this time and it was HOT! I told him I would call someboby else and not to tear up his winch. We unhooked it from my truck and the winch will not pull the cable in. It will just click. The motor will turn backwards letting the cable out fine. It just clicks when you are trying to let the cable in and it doesn't turn over or anything? This happened last night and he has tried it today with the same problem. We also tried a different remote. Anyone have any idea what is wrong.;
Old Mar 6, 2005 | 05:19 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
sounds like the brushes burnt up, but im no winch expert.....
Old Mar 6, 2005 | 05:44 PM
jopey's Avatar
jopey
sounds like the most typlical problem in any electrical item. Bad connections. Check everything over. I was using my buddy's xd9000 and we stalled it. Never even got warm. You could hold your hand on the motor.
Old Mar 6, 2005 | 05:55 PM
fishmanndotcom's Avatar
fishmanndotcom
either you burnt the motor up (not really that big of a deal) or like jopey said your connections are bad. that clicking noise is the same noise you hear when trying to crank a truck and the battery is dead...means it ain't getting enough juice!
-cutts-
Old Mar 6, 2005 | 05:58 PM
99ls1z's Avatar
99ls1z
If the connections are bad would the motor still work in reverse letting the cable out? It only click when trying to pull the cable back in.
Old Mar 6, 2005 | 06:48 PM
fishmanndotcom
yes b/c there are different connections... one for reall out and one for reel in. on my 8274 there are 4 solenoids that could go bad or could have a loose connection. open up the electrical box and scope out any loose wires (jiggle'em).
-cutts-
Old Mar 6, 2005 | 09:36 PM
mark a.'s Avatar
mark a.
My "junk" Ramsey has started doing the same thing, but no click. The hand switch on the end of the plug in cable is bad. Whats next with my piece of junk ?
Old Mar 6, 2005 | 10:23 PM
fishmanndotcom
the case will break from the supports on the top letting loose! happened every single time with mine
-cutts-
Old Mar 7, 2005 | 01:44 AM
justshootme84's Avatar
justshootme84
I burned the motor up on a Warn 8000 the same way. It worked great on my 86 Ranger, but the first real stuck on a 3/4 ton truck just burned it up in seconds. It ain't supposed to get hot!!!
Old Mar 7, 2005 | 06:58 AM
mark a.'s Avatar
mark a.
Thanks Fish now I've got something else to look forward too
One thing I have learned is to always use a ****** block on anything, no sence in adding any more stress to the old girl than necessary.
Old Mar 7, 2005 | 07:39 AM
fishmanndotcom
sorry man... i only speak from experience! the best thing to do is be VERY careful about non-straight line pulls. don't let the cable bundle up on one side. trust me, that pot metal case doesnt hold up all that well, lol
-cutts-
Old Mar 7, 2005 | 07:48 AM
74 bronco's Avatar
74 bronco
I had 9000xdi it did the same thing and was the soliode that were bad how I found out I called warn told me switch the power cables on winch motor se if work in the oppsite direction if does the seloinds are bad if not motor is bad.
thanks clint
Old Mar 7, 2005 | 09:37 AM
99ls1z's Avatar
99ls1z
I will start with the electrical part and go from there.
KC8QVO
Offroad & 4x4
Oct 27, 2014 06:30 PM
steve(ill)
May 1, 2014 11:19 PM
kevinrea
Oct 13, 2010 12:59 PM
rbloodhound
Offroad & 4x4
Apr 24, 2007 09:26 AM
is300wrx
Offroad & 4x4
Dec 5, 2006 09:24 PM
