Need help interpeting codes
Old Mar 6, 2005 | 04:34 PM
BigBertha's Avatar
BigBertha
91 Ford Ranger XLT, 92,000 miles 2.3L
A few weeks ago, I was having trouble with the check engine light. Naturally, when I took it to the shop everything worked and they said that they couldn't find anything. I bought an Actron code reader and pulled the following codes:
18 -
loss of TACH signal to ECA;
DIS fault - primary circuit faliure in coil pack 1,2,3 or 4;
Electronic EDIS fault - failure in SAW circuit.
After I pulled the codes I checked the coil pack. Low and behold one was not connected securely. I also noticed a hardened substance (probably from the grease in the spark plug boot). I cleaned all the boots (4) and regreased them. It started and ran like a charm for 1 day before the light came back on.
Question:
What's next?
And IF I have to take it in to a shop (which is very possible) what should I expect them to tell me. OR do you think that a novice/enthusiast like me can get the job done?
P.S. Has it been any of your experiences that a code 18 can cause my engine to fail?
Thanks in advance.
Old Mar 6, 2005 | 06:17 PM
Rockledge's Avatar
Rockledge
Dtc 18/212
Pull the codes again, it might not be the same code being thrown.
DTC 18/212 indicates a loss of IDM input to the PCM.
Possible Causes:
-- Open harness circuit.
-- Shorted harness circuit.
-- Damaged Ignition Control Module (ICM).
-- Damaged Powertrain Control Module (PCM).
The IDM signal is sent from the DIS Module to the PCM when a coil fires, the circuit runs between the two components.
Based on the above, you have either (1) a short or open in the wiring between the PCM and DIS Module, (2) the DIS Module itself is bad, or (3) the PCM is bad. Nos. 1 and 2 are more likely.
Here is a diagram of a typical DIS system showing the relationship of the IDM circuit to the rest of the ignition components, it's for a 6 cylinder but the systems are identical otherwise:
Old Mar 6, 2005 | 08:15 PM
AlfredB1979's Avatar
AlfredB1979
I thought code 18 related to the TFI going bad. Though, I have heard that will not always set off a code.
Old Mar 6, 2005 | 08:30 PM
Rockledge's Avatar
Rockledge
The TFI serves a similar function in a distributer-based ignition system, the 2.3L has DIS and hence it's now known as the DIS Module.
Old Mar 7, 2005 | 04:40 PM
BigBertha's Avatar
BigBertha
Pulled the codes again.
got code 18 again and
code 88 - Loss of dual plug input control
IF that it is the case, is this a job for a specalist.
Also, just wondering. Could the codes come up as a result of bad spark plug wires in the coil pack?
91 ford ranger xlt 92,000 miles
2.3l engine
Old Mar 7, 2005 | 08:17 PM
Ken00's Avatar
Ken00
I would run the pinpoint tests, if you need them let me know, you'll need test JC & MC.
Old Mar 8, 2005 | 05:46 AM
BigBertha's Avatar
BigBertha
Dumb Questions?
What is a pinpoint test and what is test JC and MC?
Just asking. I may know them by other names.
Old Mar 8, 2005 | 07:04 PM
Ken00's Avatar
Ken00
A pinpoint test is a series of tests used to determine the specific cause of a code.
The MC & JC are just the names Ford gives the test, MC = spout check, JC = Electronic ignition system.
jrjax
152
May 30, 2013 10:35 AM
Justin's Green Truck
Mar 30, 2013 10:08 AM
Rarj4ever
Aug 15, 2012 01:17 PM
-=Pit=-
May 19, 2011 09:30 AM
gbone00
Apr 8, 2004 12:54 PM
