What the .....engine just quit!
Old Mar 6, 2005 | 01:56 PM
LeafAngel's Avatar
LeafAngel
Unhappy What the .....engine just quit!
I have a '00 X w/ V10. The other day I pulled out of the driveway and started down the road. I hadn't gone 100 feet and the engine just quit . No missfire or warning, just like someone flipped a switch . I coasted to the side of the road , switched the key to off and looked things over. Nothing unusual under the hood or on the dash. I climbed back in and it started right up and has run fine since. Any ideas?
Thanks!
Leaf
Old Mar 6, 2005 | 02:04 PM
Sagegrouse's Avatar
Sagegrouse
Does anyone know if Cam Position Sensors (CPS) are a problem with the gas engines as well as the diesel? Could be that.
SG
Old Mar 6, 2005 | 06:35 PM
lockdoc600's Avatar
lockdoc600
Happened to me one day in my 00 X PSD too.....fuel pump fuse blew!! Start small it may be all it is.
Old Mar 7, 2005 | 05:38 PM
idepinto's Avatar
idepinto
Yes My X does that now and then and allways starts rite back up.
Old Apr 3, 2005 | 07:13 PM
Ron0726's Avatar
Ron0726
Idle Air Control Valve
I had a similar problem. My X would start and then stop. It initially started idling rougher and then got to the point of having to drive with foot on gas peddle to force it to "idle". I was told to replace the Idle Air Control Valve (IAC) on the intake. I took it off and it was gunked up with soot. I cleaned it with rubbing alcohol and replaced it. It ran just fine afterwards and I improved the gas mileage. The problem started at about 90,000 miles. It only took about 1 hour to pull it off, clean it, and re-install. Saved about $200 between part and labor.
Old Apr 3, 2005 | 07:44 PM
huntercgr's Avatar
huntercgr
Could it be something as simple as the fuel filter?
Old Apr 3, 2005 | 07:46 PM
Ron0726's Avatar
Ron0726
I replaced the fuel filter, changed the oil, and the spark plugs and problems continued until the IAC valve was cleaned.
Old Apr 4, 2005 | 04:16 PM
MikeRizz's Avatar
MikeRizz
My X was doing the same thing last summer, it was the IAC. The dealer replaced it ( under warranty ) and it has been fine ever since.
jayessdub
Feb 27, 2014 09:43 PM
ranger714
Aerostar
May 26, 2010 05:51 AM
Vinford
365
Oct 27, 2009 09:42 AM
Greenrvrcat
1997 - 2003 F150
Nov 28, 2008 08:41 PM
Miz Mary
Aug 29, 2003 09:36 PM
