engine cut out- neutral safety switch ?
Old Aug 29, 2003 | 11:57 AM
Miz Mary's Avatar
Miz Mary
Driving down the road, no warning whatsoever and the engine dies. I dont get any electrical working when this happens. Sometimes it will start back up on its own about 4 seconds later.
Recently replaced steering column with one that doesnt quite fit right,and was wondering if the neutral safety switch was getting triggered and thus cutting off engine/electrical ? '77 Ford F 150
Old Aug 29, 2003 | 12:11 PM
Mil1ion's Avatar
Mil1ion
No, that is only used when you are starting the engine.
You proabably have a bad ignition module.
Do you have any test equip ,like a test light or Multi-meter?
Old Aug 29, 2003 | 01:28 PM
beartracks's Avatar
beartracks
If you are also losing your gauges I would suspect the ign. switch or wiring.
Old Aug 29, 2003 | 09:36 PM
Miz Mary's Avatar
Miz Mary
I just found the page in the repair manual that shows where the little pin is for adjusting the neutral safety switch, which was never done when the new steering column was put in. We have done this adjustment and will see if it still does it !! Thanks y'all !
bigcountry150
Mar 11, 2011 12:51 PM
onetwin
3.0L V6
Sep 24, 2006 01:35 PM
Mil1ion
Electrical Systems/Wiring
Nov 29, 2002 08:00 PM
joseph
Nov 2, 2002 08:47 AM
cpnhgnjnky
Sep 14, 2002 05:52 PM
