Stuck intake valve?
Old Mar 5, 2005 | 11:59 PM
351M's Avatar
351M
Stuck intake valve?
My '87 6.9 seems to run fine tilkl I run down the highway and I mean really run it hard, then when I stop it has a thump in th intake almost like a valve staying open. any ideas? after shut it down for an hour its fine again.
Old Mar 6, 2005 | 12:53 PM
351M's Avatar
351M
Well, we have to oil consumtion problem but the valve just sounds like it is sticking open a little bit, but it only does it while it is warm, after some realitivly high rpm highway driving, then it will stay that way for about an hour after shut down, after that its fine again till its used on the highway again. I'm going to go run it today and pull the valve covers off to see whats up, I'll let you know what I find.
Old Mar 6, 2005 | 10:13 PM
bilder12's Avatar
bilder12
i seem to think that you could hear a valve problem in the exhaust pipe. After you get it to op temp, try to loosen the injection line to each cylinder and see if there is one that makes no difference. It will either show up an injector or a valve skip. Hope this helps you out.
Old Mar 11, 2005 | 12:20 AM
351M's Avatar
351M
I found the problem, an intake valve was sticking. My old man hasn't been checking the oil in it. I backed out of the driveway and hit the brakes and the oil pressure dropped, filled it and all is well now.
SteevenH
1997 - 2003 F150
Mar 29, 2014 12:20 PM
nuts4hotwheels
General Automotive Discussion
Aug 9, 2010 05:26 AM
JohnBOV43159
Mar 24, 2010 04:22 PM
Links_vette
Mar 24, 2009 04:15 PM
jbondi
1978 - 1996 Big Bronco
19
May 25, 2005 09:45 PM
