Air Injection Pipe
Old Mar 23, 2010 | 09:14 PM
JohnBOV43159's Avatar
JohnBOV43159
Air Injection Pipe
Today I noticed a hole had rotted through the check valve part on my intake manifold air injection check valve. This is the pipe that comes up out of the intake manifold just behind the thermostat, makes a little bend up to the valve and then a hose runs out of the valve and down to the smog pump. Its a 1977 351M. I grabbed the valve and it completely broke off of the pipe. I am assuming that I probably have some vacuum problems at the least.
What does this valve do? Can I just plug it off at the manifold? The smog pump doesn't even have a belt on it so I don't care about making any of the smog stuff work, just want the truck to run its best.
Old Mar 23, 2010 | 11:11 PM
JohnBOV43159
I tried to start the truck with the injection pipe from the intake manifold open, valve broken off and hose unattached, truck wouldn't start and smoke billowed out of the carb.
I just attached the hose coming up from the air/smog pump to the pipe where the valve broke off and the truck started ok. What's going on?
Old Mar 24, 2010 | 04:04 PM
JohnBOV43159
Guess I'm just talking to myself but today I took all the smog crap off the truck and put a 3/4" aluminum pipe plug I got fro the hotrod shop into the Edlebrock intake manifold and the truck runs 100% better than it ever has.
Old Mar 24, 2010 | 04:11 PM
Poison Oil Racing's Avatar
Poison Oil Racing
see, talking to yourself worked
Old Mar 24, 2010 | 04:22 PM
JohnBOV43159
Yep, sometimes I even cuss at myself!
rwsam
13
Jul 25, 2019 10:10 AM
BigBlocker0248
Feb 29, 2016 06:20 PM
Soarer
Aug 18, 2014 05:19 PM
Chevellenut1973
Jun 23, 2014 05:07 PM
Derrick lane
18
Oct 19, 2010 09:32 PM
