bad head gaskets
Old Mar 5, 2005 | 07:11 PM
04 LARIAT STROKER's Avatar
04 LARIAT STROKER
bad head gaskets
i talked to a diesel tech from ford the other day and he said they were having roblems with the head gaskets blowing out on the 6.0...i asked him about it because my 04 has wet spots on both sides of the block and pukes white smoke somtimes like it is burning water....anyone else hear anything?
Old Mar 5, 2005 | 07:13 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
not yet and nothing showing on our 04... anyone heard of a bulletin on this?
Old Mar 5, 2005 | 07:22 PM
04 LARIAT STROKER
i am gonna take the truck into my local dealer and see what is up...i have rn the predator and have a straigt pipie and gauges so i will put the stock exhuast on and take out the program...before the truck is completely to operating temp., i will be accelerating and just about when its time to push the clutch in, the truck will puke white smoke and stumble...when it is totally warm, it doesn't really do it...i ges i will just have to have them check it out since it is still under warranty.
Old Mar 5, 2005 | 07:27 PM
bigredtruckmi
Veteran: Navy
Hopefully it will give them some codes to work with.... keep us posted.
Old Mar 5, 2005 | 07:39 PM
04 LARIAT STROKER
i just hope the predator doesnt throw any codes for them
Old Mar 5, 2005 | 07:45 PM
bigredtruckmi
Veteran: Navy
not sure on that one maybe someone else knows...
Old Mar 5, 2005 | 08:47 PM
dogdude2003's Avatar
dogdude2003
Wild guess... EGR?
Old Mar 5, 2005 | 08:59 PM
MIKE1646's Avatar
MIKE1646
Why is that the EGR is always giving problems?
Old Mar 5, 2005 | 09:25 PM
bighoss550's Avatar
bighoss550
thats not an egr problem. its almost certainly a timing problem. if it were head gaskets, u would know. under the force of cyl press in a 6.0, head gaskets wont take much time to make up their minds u may have an external leak, tho.
Old Mar 5, 2005 | 09:53 PM
dogdude2003
hmmm another wild guess...injector?
The reason I guessed EGR is the puff of white smoke. I get that when my EGR acts up...it idle's down down down to almost a konk...then it revs itself up up up with a puff of white smoke. and repeat. Unplug the EGR, it stops instantly. With a manual tranny...maybe it does it the way you described?
Beats me...good luck with it. I'm with ya.
Old Jul 11, 2005 | 02:08 PM
texashank's Avatar
texashank
Question Bad Head Gaskets
I had an 03' 6.0L and had the white smoke, the dealer said it was the EGR and replaced it. However, I did not keep the truck long enough to find out if that was the cause.
I have an 04' 6.0L now. I took it to the dealer today b/c of 2 symptoms. First, I could smell anti-freeze periodically, even though truck did not run hot and I did not notice any leaks. Second, I noticed white smoke on WOT, especially under load (towing 5K lbs).
The dealer said it was a clogged EGR. The EGR was causing the turbo to not work properly, and that was causing slight overheating and thus the anti-freeze smell. They said that I may have gotten some bad diesel and that caused the clogged EGR.
Old Jul 11, 2005 | 06:59 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome texashank, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
See you on the boards.
Enjoy FTE …..
mickpowell1967
Sep 8, 2009 08:29 PM
rustynuts
Feb 13, 2009 11:21 PM
4x4k20
May 12, 2008 03:46 PM
rileyp
Dec 8, 2006 03:09 PM
werkdatool
Aug 20, 2002 03:42 AM
