Stroker 300's?
Old Mar 4, 2005 | 08:33 PM
wrkhrs6's Avatar
wrkhrs6
Question Stroker 300's?
Has anyone here heard of a stroker crank for the 300? Anyone have any idea what would be the max increase? I figure if your strength is low-end torque, then go with it. Any of you who have ever driven an International I-6 will know what I'm talking about. 400+ CID 6's.
I have a 94 F150 ext. cab with AOD tranny, 3.08 rearend, and 220K miles on it. I get consistent 18-20 mpg out of it. I also just bought my daughter a 74 F-100 with a 3-in-the-tree, 300, and 3.35 front-loader 9" rearend. The 74 has a VERY solid body, in need of some TLC and paint. I was figuring to use it for a test bed before doing any work on my truck.
BTW, you HAVE heard that Ford is targeting a Ford-build Inline 6 diesel for 2007, haven't you? ;^)
Old Mar 4, 2005 | 08:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Mar 4, 2005 | 09:00 PM
oldhalftons's Avatar
oldhalftons
I've never seen or heard of a stroker crank for the 300. The only ive ever heard of is offset grinding the crank .010-.020" to bring the stroke up to 4".
BIG sixes can be fun. Sometimes a get to drive a old International grain truck with 855cid Hercules strait-6
5.5" bore, 6" stroke, 5.5:1 compression ratio
It will run like a top on cheapest, nastiest gas you can find.
It will run on stuff that's barely paint stripper with water in it.
Old Mar 4, 2005 | 11:50 PM
Col Flashman's Avatar
Col Flashman
You need to find an all Steele Crank fore there are No stroker cranks.
If you read this intire thread you'll find out everything you need to know to.
https://www.ford-trucks.com/forums/s...ight=built+300
Cheers
Colonel Flashman
Red '58 Merc. M-100 HP 300 (bored to 312) I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Old Mar 5, 2005 | 12:19 AM
Schmids4.9l's Avatar
Schmids4.9l
If ford puts a inline six diesel in the fseries in 2007 i would be happy. also the 300 is already stroked. its a stroked 240.
5.5:1 compression! wow. imagine putting a turbo on it, you could probobly run 30 lbs of boost, and still run off pump gas!
Bennie Morton
Apr 6, 2017 09:47 PM
Russ74
Mar 25, 2017 01:59 AM
f1001969mike
1997 - 2003 F150
Mar 18, 2014 09:50 PM
The Freak
Oct 24, 2007 11:40 AM
snizzitch
Oct 19, 2001 05:01 PM
