squeaky speedometer
Old Mar 3, 2005 | 09:14 PM
jbailey's Avatar
jbailey
Question squeaky speedometer
I have an 86 4x4 150 with a squeaky speedo. How does the cable come off the speedo? There's a plastic clip, I can't get it loose and I'm worried I'll break it. Also what's good to lube it?
Old Mar 4, 2005 | 08:33 PM
Franklin2's Avatar
Franklin2
Push the clip to one side, and it should release. Squeeze it inward toward the center of the cable.
Old Mar 6, 2005 | 02:54 AM
bill1958's Avatar
bill1958
Franklin is right. You have taken off pad? It won't come off easy, and not much room to work. Try unbolting and pulling cluster out A LITTLE forward to give you more room
