class b van conversions?
do any of you have info on these?
or have had one?
what kind of ementities(sp) do they offer.
what engine options and mielage do they get.
i was also looking at a few of the vw vanagon type vans.
which is a better choice.
i would need to buy one used no more then 10,000.
thanks for any info or links anyone has.
Example, a friend's father (mechanic for 40 years) was looking for one for quite some time to camp at blues festivals and finally found a used mid 90's Dodge RoadTrek with high miles and needed work. He paid $17k for it. He said he was shocked at how much they went for.
Most are Dodge or GM. Ford Class B's are rare. I'm not sure why... something to do with the frame design, I think...
www.roadtrekcom
Mileage is on par for a loaded van (low to mid teens). Most have mid to large V8's. Diesels are rare for some reason.
Amentities are the same as any other RV, just more compact and have a smaller fluid capacities. And in some, require some set-up. In my friend's RoadTrek, the shower is inset into the main corridor and is creatd by pulling two curtains out. Works well enough, but blocks access from the front to the rear while in use.
The VW vans are nice, but they're VWs... and well... that brings with it their own set of "pluses and minuses." They tend to be expensive to buy and maintain, although reasonably reliable if maintained.
Building your own van camper is an option, lots of guidance on the web about ways to do it.
If you travel alone, or with one other hardy person, building your own is a fairly good idea.
If I were to look for another Class B RV / camper van, I'd go with one of the Sportsmobiles ... www.sportsmobile.com
From what I've seen, they're pricey, but overall the best deal for the money.
And amenities galore.
My first choice would be a 1998 - 2002 Ford E350 extended van, ideally with the older 7.3 diesel.
If not that diesel, then 5.4 V8 or the V10.
I'd probably avoid th 4.6 V8 .. just not enough engine.
Your van camper will be heavy, and a too-small engine will use more fuel than a larger one
that doesn't have to work itself to death.
With the V10, look for 2003 or newer.
The V10 engine and the whole van got a major upgrade beginning model year 2003.
Always use E load range tires, avoiding tires that are designed even partially for off-road.
Off-road tires tend to squirm on the highway, feeling like the front end needs alignment.
Choose all-terrain tires, they're more highway-friendly than tires that have off-road capability.
Make sure it has a class 3 hitch, you'll probably tow something.
I've built 6 van/campers since the 70's, all of that was really educational, and a LOT of work.
My present one, an 04 E150 standard wheelbase van, is a "stealth" camper ..
it looks like any other passenger van ... makes for easy camping at McDonald's or Walmart.
I'm over 70 now, so I might not build another one.
I built 2 Chevy's and one Dodge, but durability-wise, and ease of maintenance,
today I'd go with a Ford.
The Chevy's were the most fun to drive and handled the best, and the Dodge was the winner for sheer engine power,
but the Fords always got me there, and got me back home every time, and are pretty easy to work on.
Not always true of the Chev and Dodge.
This is a simpllification, but having been there, it's my view of things.
