Computer Chips & Tuners
Predator's diagnostic capabilities??
Old Mar 2, 2005 | 05:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I'm in the market for an OBDII diagnostic tool, and for the price (especially since it happens to have a 100 horse program) the Predator is definately in the running.
My questions are: Will the Prdator scan all OBDII vehicles, or just the Ford OBDII, or just my truck (see sig.)
Also, from Motorhaven's Predator ad it lists:
"Full text OBD-II Diagnostics + diesel specific diagnostics
Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.). Over 100 parameters can be monitored in real time."
I am interested in three of those "over 100" parameters. 1. the duty cycle of the injection pressure regulator. 2. High pressure oil pressure, and 3. Fuel injection pulse width.
If it can capture those three parameters from my truck, and read the rest of my OBDII Fords (00 Windstar, 01 Taurus, and 97 Navigator) then I'll be sold and will purchase one based on reply's to this thread.
TIA
Cookie
Old Mar 2, 2005 | 06:46 PM
LxMan1's Avatar
LxMan1
Yes, it will test any OBD-II system. I used my F-Series Predator to scan a Nissan and it worked fine. It will just only tune one vehicle at a time. Definately worth the money.
Old Mar 2, 2005 | 06:58 PM
cookie88's Avatar
cookie88
FTE Emeritus
Terrific. Thank you much. Any oil burners have any input on the other parameters?
Old Mar 2, 2005 | 09:53 PM
Kwikkordead's Avatar
Kwikkordead
Cookie I would also try and find out if the Predator can also adjust injector pulse width, duty cycle, and injection timing also, so you can fine tune it to your heart's content. That would make it a killer app. If it would do all that I wouldn't bother with chip when it's my turn to do it.
Old Mar 2, 2005 | 10:39 PM
cookie88's Avatar
cookie88
FTE Emeritus
I don't know if it's truely bi-directional or not, but for me it does not need to be....I just need to be able to monitor so I can better direct my chip guy on the improvements I want, and it's absolutely neccessary that it can read all my vehicles.
It's looking more promising all the time, check out my same subject thread in 7.3
Old Mar 28, 2005 | 12:06 PM
FTE Ken's Avatar
FTE Ken
No, the Predator will not allow you to adjust pulse width, duty cycle and injection timing. The only thing you can modify on the supplied tunes is shift pressure.
Old Mar 29, 2005 | 08:38 AM
Kwikkordead
Bummer. I would like to find a way to retard the timing on my rig. It pings like a gasser with the timing way too advanced while on the freeway. I know it's just a diesel going about it's work, but I know it could use a little adjustment.
FTE Ken
2004 - 2008 F150
201
Jun 29, 2008 08:07 AM
FTE Ken
Feb 22, 2006 08:44 PM
cookie88
Oct 4, 2004 09:07 PM
sledhead999
Aug 13, 2004 12:45 PM
FTE Ken
Mar 14, 2003 06:18 PM
