Diablo Predator Updated???7.3L
Old Aug 12, 2004 | 03:24 PM
sledhead999's Avatar
sledhead999
Has the Diablo Predator been updated? Here is what is on GranatelliMotorSports website.
Four Tunes Available:
• Hellion Tune - Adds 0HP/0ft/lb TQ (allows use of other aftermarket chip/tuning plus all other
functions of Predator apply including diagnostic scanning, rev limiter, speedometer calibration)
• Tow Tune - Adds 40HP and 100ft/lb TQ (manufacturer suggested weight limits)
• Economy Performance Tune - Adds 60HP and 150ft/lb TQ (recommended weight limit 8,000 lbs,
larger diameter performance exhaust & exhaust temperature gauge recommended)
• Performance Tune - Adds 120HP and 240ft/lb TQ (not recommended for towing, larger diameter
• Exclusive! Extends speed limiter to 120 mph (may vary based on vehicle setup, weight,
tire size, 2wd vs. 4wd etc.)
• Exclusive! Adjustable shift points (does not apply to manual transmissions)
• Exclusive! 300% larger backlit screen
• Exclusive! Fastest re-tuning times on market (Performance Tune takes 45 seconds)
• Exclusive! Custom tunes & updates through Internet
• Exclusive! Re-tune vehicles after factory re-flash of PCM
• Exclusive! Multi-vehicle DTC scanning & erasing work plus live data monitoring
• Exclusive! Contains all diesel specific "P" codes for the vehicle
• No computer skills required, installs easily
• Limited lifetime warranty - Read our Predator Liability Waiver
Here is what motorhaven lists for Diablo specs:
NEWLY UPDATED!
DiabloSport has just released their latest version of the Predator programmer. The Predator has new and improved tuning
for cooler EGT's (exhaust gas temperatures) and smoother driveability. Options include: Features
Easy to use. Novice users can select preset performance settings.
5 Performance settings!
tow file, 40 HP, 110 ft/lbs torque
60 HP, 145 ft/lbs torque (fuel economy performance tune)
85 HP, 190 ft/lbs torque
100 HP - 200+ ft/lbs torque, new feature!
altitude (tow file specifically made for high altitude) new feature!
transmission adjustments (none, firm & hard)
speed limiter adjustments
State of the art OBD-II diagnostics live sensor reading (not just a simplistic code reader)
up to 30 minutes data logging at 90 samples per second that can be viewed on the Predator screen or uploaded to your desktop pc new feature!
even quicker programming time (less than 2 minutes)
custom or modified files can be uploaded into the Predator without sending in the unit
300% larger viewable screen than other brands.
Backlit screen allows you to use the tool in full sunlight or total darkness
Full text OBD-II Diagnostics + diesel specific diagnostics
Real-time sensor input data monitoring (fuel, MAP, coolant temp, RPM, live diagnostic codes, etc.). Over 100 parameters can be monitored in real time.
Read and clears DTCs (Diagnostic Trouble Codes) with full text DTC explanation.
Can reprogram performance tune or restore stock tune even if dealer reflashes the ECU
Port which will allow future download of updates and customized programs
Lifetime Warranty!
Which one is more current.
Thanks.
Old Aug 12, 2004 | 05:34 PM
99PSDCREW's Avatar
99PSDCREW
I installed the Diable Predator about 45 days ago and received the latter described by Motorhaven, in fact bought them there. Don't know about that other company's description. I'm happy with the 60HP setup while towing 4,500 or not towing. 99PSDCREW
Old Aug 12, 2004 | 08:38 PM
sledhead999
99PSD,
What did the letter from motorhaven have to say?
Also, GranatelliMotorSports is supposedly the company contracted with Diablo to market the tuners.
Old Aug 13, 2004 | 08:19 AM
FTE Ken's Avatar
FTE Ken
There's nothing new about the 7.3L Predator...
They are simply publishing the numbers from dyno results rather than the numbers Diablo publishes. Also, the 45 second time verses the 2 minute time is because they are listing the reprogramming time (ie, if you program it a 2nd, 3rd, 4th, etc. time). MotorHaven lists the initial programming time which takes longer because it has to save a copy of your stock program.
A correction... Granatelli Motor Sports is not the company Diablo Sport contracted with. Rather, it is one of two companies. The first, PDQ Performance and a few years later Granatell.
Old Aug 13, 2004 | 11:24 AM
sledhead999
Ken,
Thanks for clearing up some confusion. Interesting how some people inter. things differently. Thanks again.....Sledhead999
Question: What about the 0HP/0TQ gains with the addition of a extra chip. Is that the same as it always has been?
Old Aug 13, 2004 | 12:33 PM
FTE Ken's Avatar
FTE Ken
A chip has always been able to override a tune. That tune isn't there for that (don't know why GMS thinks it is). Its there so you can do tranny mods with stock power. Putting a chip in will override any power setting so there is no need for a tune specifically for a chip.
Old Aug 13, 2004 | 12:45 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
So you actually can run both at the same time?
If my buddy that runs an SCMT wanted to try my chip, we could just plug it in and run it without resetting the stock programming first?
FTE Ken
Feb 22, 2006 08:44 PM
FTE Ken
1997 - 2003 F150
30
Mar 10, 2005 09:37 PM
FTE Ken
22
Sep 27, 2004 08:37 PM
FTE Ken
Computer Chips & Tuners
Nov 20, 2003 01:02 PM
FTE Ken
47
Mar 19, 2003 08:48 PM
