i posted this in one of the other forums, and it was suggested i post it here. So here goes. i found a snorkle set up for a carb'd toyota pickup, i want to use the same set up, modified for a EFI. i'm wondering if the tubing used on this set up would sufocate my 5.8L. thoughts on that?
thats an awesome idea! i never thought about it. try and keep the hose close to the same size as the intake hose thats already on your truck. know what i am saying? if the air cleaner hose is 4" around try and keep the snorkel not much less than 4"
I thought that most EFI's had 2 seperate 2.5" tubes going to the same place. Then you willl have to mod the intake part...that will be the only "hard" part.
Yeah thats what i meant, 2 2.5" tubes would equal a single 3.5" tube, or a 4" would do fine. For the box, you would have to comptely remove it, and where the air inlet is for the stock box you would have to enlarge it, glue/rivet and seal a fitting of sorts on the enlarged inlet hole, then hook up all your tubing
You could just leave your current ari filter and intake-to-filter tubes where they are. Then reroute the filter intake through the hood and up the A pillar.
That guy used that ribbed tubing stuff, wouldnt that effect ariflow? (Im a diesel guy, and air is everything)
