weatherstripping
Old Feb 28, 2005 | 11:09 AM
Ian Mike B's Avatar
Ian Mike B
weatherstripping
Just finnished replacing all seals, glass, and glass runs on the left door of my 1950 F-3. When I rehung the door I had to remove the weatherstripping on the door to get it to close. I think its too thick, could hardly get the door to the first notch on the stricker plate with no chance of getting it to latch completly. I bought a kit from Dennise Carpenter and it looked like good quality stuff. Does anyone have any sugestions. Thanks
Old Feb 28, 2005 | 11:42 AM
Randy Jack's Avatar
Randy Jack
Ian -
Funny thing about that. It is a typical problem.
There is a recent thread that talks about a thinner strip available from Mid-Fifty. See if they have something for your 50.
https://www.ford-trucks.com/forums/s...d.php?t=349463
Old Feb 28, 2005 | 12:35 PM
azwafree's Avatar
azwafree
There is ample adjustment capability to the striker plate and hinges. I hadethe same problem you are having and was able to adjust it properly, thansk to advice from members.
Old Feb 28, 2005 | 03:48 PM
51ford fan's Avatar
51ford fan
Welcome to the club !! I'm having the same issue on my 51. If that rubber can be cut down to a thinner diameter and still look good I would sure like to know how to do it.
Rod
Old Feb 28, 2005 | 10:01 PM
Randy Jack's Avatar
Randy Jack
51ford fan -
I have not done this myself, but have heard that carefully cutting away the "heel" of the seal with a razor blade is the way to go. This adjusts the strip thickness without changing the sealing edge itself. The nasty adhesive fills any irregularities in the cut edge.
Old Mar 1, 2005 | 09:18 AM
bradoemba's Avatar
bradoemba
Without trying both, is their a good way to determine which will fit best? I can see daylight through my door frames, and I made the mistake of going through a car wash this weekend which dumped a river of water into the cab. I think bigger will be better, but who knows. I suppose I can go big and trim as mentioned above.
Old Mar 1, 2005 | 09:25 AM
Randy Jack's Avatar
Randy Jack
Brad -
I saw a tip on a hoaky car TV show (Two Guys Garage) where they glued a rubber shim between the weatherstrip and door jamb to thicken the seal in those areas. Used smoke from inside the car to check the sealing. This rubber shim material is supposedly available at part stores, dealers or glaziers.
Old Mar 1, 2005 | 02:52 PM
fking1's Avatar
fking1
This is how I solved the same problem on my 55. Using a piece of heavy paper, place it over the seal and close the door to find the tight spots(pull on the paper). I used a box cutter, razor blade and rotary file (burr) in a die grinder, to cut the seal thinner. Working around the door I eventually got a perfect fit. Takes a bit of time and patience.
Fred K.
Old Mar 1, 2005 | 08:53 PM
51ford fan's Avatar
51ford fan
Originally Posted by Randy Jack
Brad -
I don't think Two Guys Garage is hoaky, I watch it every week. I would still like to know if that Counteract unit they installed on Sam's 38 actually works.
05MilMachine
Feb 25, 2016 06:50 PM
John R. Thomas
Jul 29, 2013 07:47 PM
bucks77ford
Jan 19, 2013 06:51 AM
Sw1tchfoot
30
May 5, 2011 08:56 PM
matt2491
Feb 21, 2009 09:00 PM
